Old 13th March 2016, 06:21 PM
Scottnybottny Scottnybottny is offline
Default Update
Sunday,13,March,2016,18:54:57:07419
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
Mileage: 166180km-103259mi Repair Order:
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 409 A HW: 4E1 907 409
Component: 4.2L V8TDI G000AGMª0070
Revision: --H01--- Serial number: AUX3Z0E9376803
Coding: 0011773
Shop #: WSC 00783 210 84012
VCID: 224BBD6DFDD30A2E48-8076
2 Faults Found:
000408 - Engine Oil Temp. Sensor (G8)
P0198 - 000 - Signal too High - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 166167 km
Time Indication: 0
Date: 2016.03.13
Time: 17:51:58
Freeze Frame:
RPM: 1428 /min
Torque: 89.7 Nm
Speed: 55.5 km/h
Duty Cycle: 18.1 %
Voltage: 14.36 V
Temperature: 9.0°C
Temperature: 70.2°C
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 166172 km
Time Indication: 0
Date: 2016.03.13
Time: 17:57:44
Freeze Frame:
RPM: 1176 /min
Torque: 3.9 Nm
Speed: 48.4 km/h
Duty Cycle: 0.4 %
Voltage: 14.44 V
Bin. Bits: 00101011
Torque: 440.7 Nm
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 P HW: 09E 927 156 B
Component: AG6 09E 4,2lTDI RdW 0030
Revision: --H01--- Serial number: 0070556
Coding: 0001001
Shop #: WSC 02313 785 00200
VCID: 306F4725A33FA8BECE-8064
1 Fault Found:
009783 - Torque Management Feedback Signal A
P2637 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 40
Mileage: 166167 km
Time Indication: 0
Date: 2016.03.13
Time: 17:52:01
Freeze Frame:
RPM: 1472 /min
RPM: 1440 /min
RPM: 1280 /min
(no units): 36.0
(no units): 27.0
Temperature: 60.0°C
T.B. Angle: 17.6°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
2 Faults Found:
00003 - Control Module
014 - Defective
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Address 05: Acc/Start Auth.
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 109
Mileage: 159808 km
Time Indication: 0
Date: 2016.01.19
Time: 05:06:26
00166 - Access/Start Authorization Switch (E415)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 0
Reset counter: 56
Time Indication: 0
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285FAF459BEFE07E16-807C
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 37
Reset counter: 112
Mileage: 159955 km
Time Indication: 0
Date: 2016.01.20
Time: 05:02:27
Any thoughts on possible fixes? The light is still very intermittent, seems to be increased frequency in wet conditions.
Thanks again
