Originally Posted by snapdragon
There is/was a software bug in the instrument cluster causing this.
Some years needed a coding change, some a software update.
It especially happens if the headlight switch in not in 0 or auto when the ignition is turned off (ie headlights or sidelights manually on)
I think it also happened when the indicator was left on (one side parking lights).
You legend. When it was parked up, I switched the ignition off by the button and locked the wheel with the stop button so it was all off, but I'd left the headlights on. It doesn't have auto lights.
I'll set the clock again and test it.
Thanks for your help!
