There is a repair kit for the upper headlamp mounting tabs - 4D0998121. £12 a side, for T chassis onwards. If the lower mounts are broken too its probably easier just to replace the whole thing.
The alloy frame is in three pieces - one piece per side for the headlamps and a central one for the rad. You might be able to replace just the damaged piece.
