So, lets set the scene.....
Its 5am. You have a 3 week old son, who wakes regularly, a 20 month old daughter who wakes randomly and due to IT related disasters the night before bedtime was the wrong side of 11pm.
I'm due with Ben at AVP between 7 and 8, and then onto Birmingham around 10am for meetings.
Its hurling it down with good old fashioned Yorkshire rain, and despite the change in clocks, at 5am its still pitch black.
So, with best shoes, trousers and all kitted out to look professional I hop into my A8 with slightly bleary eyes and turn the key.
Confused by the lashing rain, some poor taste in music blaring and the blowers taking off at supersonic speed after turning the key I cant quite comprehend the rev counter failing to lift.....
... so, back her off and recrank....
Nothing.
ok, music off, blowers off, rub sleep from eye, key out, back in, check we're in park and crank..... but nothing. Worked last night at 22:30...
Ar5e.
No cranking but no dipping of instrument cluster, battery looks good, everything else is alive. Wiggled the gear shifter through the gears and back to Neutral. Still no start. Back into Park, still no start. Put it in Drive and same effect - Still no start. hmm.
Clock ticking.
I rule out battery as cause as everything else is lit up fine, and no dip in lighting suggests power isnt even been drawn, so I guess a problem with either inhibitor or the power supply block to the starter motor, the latter of which is a common problem.
05:30
So, quickly get changed... Ssshh... (kids all asleep now I'm not trying to sleep) and out with the Jack. Front drivers wheel off, lining off, check connection.
05:45
Nope, rock solid.
Try to start again, stood outside the car, and there is a slight clicking noise, like the starter is trying to move, but cant ?
This is where having a manual D2 would be a real bonus....
Running out of time now, and certainly cant do anything if the starter or solenoid are failed - Last ditch attempt was to pop the battery booster on and see if it did make any more attempt to spring into life.
It didnt spring into life, but the single click definitely sounded more like a electrical spark...
Now, I really dont know what it is, and its heading towards 6am. I cant get my car to AVP (double ar5e) and so will have to get the chuffin train to Birmingham... oh joy.
Its sat on my drive now, and it will sit there till Friday when I have a chance to look at it I guess..... Ggrrrrr...
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
