Old 5th April 2016, 11:06 PM
Yes you need online services for it to work properly, I had it in my A7 and with a permanent sim card in the dash. It downloads about 20-30 miles of detailed mapping information at a time in tranches and then uses that to do things like change the lights to point in the other direction if you have travelled across the channel. It also holds gears on the s tronic gearbox because it can then tell that certain bends are coming up ahead and there wouldn't be any reason to change up. It also used to feed into the cornering lights etc I think
