View Single Post
Old 6th April 2016, 09:07 AM
I thought the more normal process these days was to put an adhesive airtight patch on the inside.
But if it's not actually leaking, leave it and monitor regularly.
Anything applied on the outside is likely to come adrift given the wear and movement in a tyre tread.
I'd probably plan to swap it to the spare in due course, having it taken off the wheel and checked inside at the same time.
