Old 14th April 2016, 10:00 AM
Hi, and welcome.....
The analogue to digital TV tuner really should be a straight swap. No coding, nothing.
I suspect your MMI version is the most likely cause of the issue if the TV option has disappeared completely as I'm assuming the Tuner shows up in VCDS happily, and if it was majorly failed it would bring down the MOST loop and stop everything working when you swapped it in....
I'm on a mission to get folk to update their signatures at the moment with their car details, makes it much easier to help people as you don't have to explain every time exactly what car you've got
So Photos of car is a must, and so is a signature update
