Old 15th April 2016, 11:33 AM
Originally Posted by JulianHicks View Post
Be aware that the BT ECU is not a straight replacement for the Motorola ECU ...
I thought the only variance was the external aerial - the Motorola equipped cars will definitely have one, and if you swap it with a non rSap capable unit then you have an aerial cable left floating otherwise I thought it was straight swap ?
If you want to throw away the Motorola 'capability', and get basic Bluetooth handsfree, I gathered from posts I'd read in the past it really was that simple?
