Old 22nd April 2016, 08:19 PM
SilverS8 SilverS8 is offline
Question Sudden Fault codes; Engine, Gearbox and ABS
Good evening.
Was just out for a quick drive and on a on-ramp i decided since its Friday, i'll let the S get some exersize.. Flat out on 1st in manuel, hit the rev limiter and auto shifted to 2nd and then when revving just past 6000 rpm there was a clear brief misfire but it kept pulling to the end.
Eased off and there we had ABS and Traction control (the A with a ring around it) light permanent on.
Car runs perfect, no hesitation or anything, idles smoothly.
Connected Vag-Com and got these 3 fault codes
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D26
Coding: 08397
Shop #: WSC 02314
VCID: 3163549BFB280EB6C1-5140
1 Fault Found:
18265 - Load Signal
P1857 - 35-00 - Error Message from ECU
Address 01: Engine Labels: 4D0-907-560-AVP.lbl
Part No: 4D0 907 558 J
Component: 4.2L V8/5V G 0004
Coding: 05753
Shop #: WSC 00000
VCID: 346D5D8F043A3B9EAA-5140
WAUZZZ4DZYN006218 AUZ7Z0X1128479
1 Fault Found:
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 BN
Component: AG5 01L 4.2l5V RdW 1314
Coding: 00011
Shop #: WSC 02314
VCID: 76E9A78752C6698E54-5140
1 Fault Found:
18265 - Load Signal
Neither of the 3 codes above is possible to delete, shows right back up when deleted directly in the module.
I tried ENGINE-Measuring Block 32 : all 4 fields display 0 and do not change while driving.
I tried ENGINE Measuring Block 2: The G/S is a steady 0,56 at idle. I took it for a spin while logging and from what i can read out off the excel sheet it never reaches above 0,72 even at WOT and going all the way to the redline.
,7.63,5520,91.0,14.62,0.72,,,,,,,,,,
,8.00,6120,85.7,14.28,0.72,,,,,,,,,,
,8.37,6720,82.0,13.94,0.72,,,,,,,,,,
,8.75,7200,77.4,12.24,0.72,,,,,,,,,,
,9.13,6880,79.7,14.28,0.72,,,,,,,,,,
I have seen several threads in here with somewhat the same problems, but most of them also have problems with fuel banks/lambdas etc etc.
All suggestions appreciated.
Cheers.
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
