Originally Posted by A8Pete
I'd like to give this a try. I have a couple of quick questions:
- I have a 2004 A8 D3 4.0 Diesel. Is this compatible with my car;
- Where is the aux input in the boot of the car and how is it wired in. I couldnt see it in your pictures
- can the music on my android phone be controlled from the MMI interface on the dashboard. I have a cd/tv button on the centre console, then I select AV from the source option on screen
Many thanks
Sorry I haven't logged in to look at this thread for a while so I will try and answer a few questions at once:
The sound quality is excellent. 9.5/10 compared to the AMI but not as good as a CD. Equivalent to Bluetooth streaming to your home cinema.
I have the AMI but I prefer not to use the Bluetooth streaming all the time and prefer to have an ipod plugged in all the time instead. So I wanted both. This means I went for the Fusion BT-100.
Anything connected to RCA cables in the car will NOT be able to be controlled by the MMI. You would need an AMI unit for that. Since the cost of this little receiver is tiny, I wouldn't expect MMI control anyway. Happily, both the Audi phone and Fusion BT connect simultaneously and do not interfere when music is playing or a phone call is on. The phone Siri can control the music so no need for the mmi control.
To fit this unit you will need:
An Analogue or digital TV module, which has inputs for the RCA. Since specs are all over the place in different countries, you need to check your car to find out if you have the TV module and then buy and fit the Kufatec RCA cables.
When the AV1 is selected the music comes through. The screen goes blank as I have nothing plugged into the video cable. I could easily fit something but I can't be bothered. I usually change it back to the CAR page on the MMI or NAV. The music plays as normal still.
Mike
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
