Originally Posted by tc4332
Here is what I posted in July 2015
I can confirm that the Aux Output gives a video/audio signal for the RSE(Rear Seat Entertainment). The output is whatever you have selected on the MMI.
I do not have RSE so I borrowed Guy's car and used a long RCA cable to send my Output to his Aux 1 input. Whatever I selected on my MMI was relayed to his MMI.
To save any misconception here are the pinouts tidied up:-
Aux Input 1
PIN 09 – Audio Shield left/right
PIN 10 – Audio signal left white
PIN 11 – Audio signal right red
PIN 12 – Video signal yellow
PIN 13 - Video Shield
Aux Input 2
PIN 15 – Audio Shield left/right
PIN 16 – Audio signal left white
PIN 17 – Audio signal right red
PIN 18 – Video signal yellow
PIN 19 – Video Shield
Video output (only for Hybrid-Tuner)
PIN 4 – Video Shield
PIN 5 – Video signal yellow
PIN 6 – Audio Shield left/right
PIN 7 – Audio left white
PIN 8 – Audio right red
Thank you very much. Could you just clarify the numbers of the pins on the physical 20 pin plug. So If I look from the rear of the plug on the side where the cables are inserted, which is pin 1, pin 2 etc so I know following guide above which pin goes where.
Many thanks
