Old 5th May 2016, 09:35 PM
Flick the key blade out, then look on the back of the key for a small slot. Put a flat bladed screwdriver in the slot and lift the plastic gently while pulling the top part of the key with the blade in it away from the bottom bit with the buttons. It should need very little force.
Once apart, split the 2 halves of the button section with finger pressure, and batteries exposed
