  #120
Old 10th May 2016, 03:15 PM
Originally Posted by limoncello View Post
MMI version seems to be on 0065 which isnt listed on the updates (maybe because it was the first.)
god knows what map version i have, suspect i need to update
put in a giffgaff sim card, but no option for google maps, though the online services works ok. not getting the funnny sign in the display except briefy when i rebooted the mmi.
If you have a P in the firmware version before 0065 then it's the 'Production' firmware that it left the factory with. If it says K then it's been updated at some point.
Post the map database version and it should be possible to work out the age of the maps (I imagine original). I'm on 6.22.4 now
It may be a case of RTFM for Google maps access, now you've inserted a SIM, or it may need a firmware update.
Assuming yours is definitely 3G+ then it should be available.
