View Single Post
Old 20th May 2016, 10:02 AM
Hiya
Well that was a right bugger to track down in Etka!
Those are revised part numbers, as of December 2013. Cost is £100.49 each at full RRP
There's no pics within Etka for these
I guess it could be 1 faulty sensor, rather than 2, since it appears to be flagging a discrepancy between the values it's presenting. Looking at Elsawin it appears 'sender 2' is the black one (G640)
You should not change both sensors at the same time!
It looks quite involved in terms of access and isn't simply swap it and forget about it.
You also need a 27mm socket
I've attached the Elsawin page for info
