Old 25th May 2016, 09:13 AM
oldnick oldnick is offline
I'm going to take a guess that it could be down to mixing the pads up.
Perhaps each pad took a slight set on the side of the disc where it was originally, and now it is on a different disc face and doesn't sit perfectly flush?
that's my feeling at the moment , only problem is none of the local suppliers list the particular set which was only used from 1999 to 2002 on the sport model so will have to order in england ...£12 postage !
incidentally dezzy , the harder you stamp on the brakes the worse it is !
going out today , maybe a little use will show an improvement !
