My thoughts are that this is using electrolysis to make H2 + O from water inside the red box which then must go along the hose and into the intake. This will not react with the soot (carbon) unless under red hot temperatures with a catalyst such as Nickel. Also the quantity compared the air mass would be quite insignificant. It would be good for someone to show a before and after of an coked up intake.
