Old 13th June 2016, 12:12 PM
Although slightly biased I confess, I do believe you're probably better off stretching and investing a D4
The full post code match is a feature of 3G Plus, which isn't a D3 item. Allegedly, it has been enabled with some success on the 3G units, but with side affects. But if you've only got 2G you're looking at 1000's to get anything like the abilities you want.
Whatever money you throw into trying to upgrade the MMI on a D3 will add nothing to its value.
The D3 'tech' is now 14 years old, with a few upgrades along the way, and technology is moving much faster than that. Even 3G is now 7 years old...
If you just want a 'D3 4.2 Tdi' crack on as you were, but definitely head for a late 2009/2010 FL model with 3G if you can.
If you want something that you can upgrade and get more out of, the D4 is a way more modern platform imo that will feel less old for a while yet.
