Originally Posted by David's8
It further states under special notes:
"Low battery voltage (including a faulty battery) may cause Immobilizer system malfunctions and testing should be done only with a known good battery installed." Now the car has been standing for a while unused so I will put it on charge. It states that: "on rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery."
So basically, if in doubt, 'try turning it off and on again'
Certainly sounds logical though. If the battery voltage has dipped low, without completely dying (a condition we call 'brownout' in electronics), digital circuits can end up in an unknown state due to the fact that some circuits will cease to function while others remain online, effectively causing some parts of the system to crash/hang.
Hopefully those steps will fix it. If not, since it's been stood a while, I'd suspect bad connectivity due to dampness. Has it been out in the rain? How dry is your electronics box?
