Old 15th July 2016, 06:37 AM
davidamd davidamd is offline
Default d2 314mm upgrade
i have the pf 4.2 with 314mm fronts and as i have final edition 20s they look tiny.
is there an easy way to upgrade to the later size 323mm or what ever it is.
on the mk4 vw platform all we had to do was swap the caliper carrier to the 312 from the 288 and obs the 312 disks as calipers were the same.
is this so on the audi a8. i have the 8 pad setup.
or is there a way to bolt on the fl a8 s8 setup.
cheers. david
