View Single Post
Old 16th July 2016, 02:13 AM
Sorry but no, FL pads are different.
PF 314 and 323mm pads are interchangeable, officially Audi part numbers are different but you can swap them. Dezzy changed his calipers and discs from 314 to 323 and used the same pads. The difference is that 314mm pads have balancer counterweights and 323 does not. My theory is that they put weights on to reduce vibration and noise on 314 pads but removed them from 323 version to make sure they fit under smaller rims like 16"
