View Single Post
Old 27th April 2010, 08:25 PM
Originally Posted by carrotchomper View Post
Thanks all, but I'm STILL having problems... Bought an aftermarket aerial from the good folks at A8parts which turned out to be the wrong size, have a new one now (Ta muchly!) and it still doesn't want to work... Plugged it directly into the back of the Nav+ unit and have variously dangled the antenna on the roof, outside the car and in the windscreen, and still doesn't pick up satellites.
Since I've plugged it in, the available satellites display has gone from around 25/27 to 30, however at best it only shows 1 satellite as "receiving"- Which obviously won't work..
Help! Should I plug it in at the boot instead?
PS- It's actually a RNS-C unit
Connecting it further away cant possibly help.... I have seen a few units now where the aerial connection on the rear seems to have failed, ie the head unit is duff without some stripping down and resolding of (what I suspect is) a dry solder joint....
If you have got the right aerial (the SMB connector clicks on quite re-assuringly, you'd know if it was wrong) plugged directly into the rear of the unit, and it is in good line of sight of satelites (pop it on the roof for the test, not inside the car, and dont be in a built up area if possible), and you get 0 satelites received the only logical answer is for the Nav unit to be faulty.....
Edit - Given that GPS technology is 4 dimensional, and has to fix 'time' before it can get a fix on position, it can take a good few minutes to get a fix. Dont be spoilt by little handheld devices that get a fix in half a minute, you need to show some real patience here and I'd give it a good 5 mins myself before I wrote it off...
