Old 27th April 2010, 08:29 PM
Originally Posted by badger7777 View Post
My sat nav seems to have developed the same fault. I tried to use it today and it can't get a fix on my location. Had a look at the GPS Viewer menu and it says Available 30 Recieve 0.
Everything worked fine last time i used it a couple of weeks ago.
What connections are there from the receiver? Is there a connection within the boot lid which might have worked loose or does the cable run continuously to the Nav unit?
There is a connection in the boot lid, but tbh it doesnt fail. There is then another connection behind the boot trim on the left hand side where the aerial would terminate for a boot mounted (non nav plus) unit, but in your case is the full jobby, so picks up an extension that runs it through to the front of the car down the audio loom, but again failure is rare.
Start with an aerial directly into the Nav plus at the front of the car, and work back from there. Its way easier that fishing around aimlessly in the boot for the connector, which will almost certainly be safe and snug...
