You have to engage tourist mode using VCDS. It's in 55 Xenon range>Adaptation and the channel depends on model of headlights and year, but VCDS tells you.
Why it was not put in the MMI, I will never know.
When tourist mode is enabled, you can drive in any country, left or right traffic as the beam cutoff becomes flat.
