Old 2nd August 2016, 12:59 PM
There is no sensor in the mount, only valve. At idle valve opens to allow liquid in the mount move more freely and absorb vibration. Under load valve closes to reduce engine movement. I think by default valve is closed so if it has failed you will have more vibration at idle but it's hard to notice. Sometimes it's just corrosion in the plug.
