Old 3rd August 2016, 07:54 AM
Nice idea David
I've been planning to do something similar myself. Like you, I have a parking area but no garage. I had been considering putting up four timber posts then using something like corrugated clear acrylic sheeting as a roof.
Are you sloping the roof to allow the rain to run off?
I intend using Ariel Plastic's Corolus corrugated PVC either 1.1mm or 1.3mm. They do a 0.9mm version but I have been warned off that. B&Q do a good price atm. Polycarbonate is v expensive but stronger. The recommended slope is a minimum of 5deg with 10deg being better for run off. I am going with 5 deg.
I would say that if you want to get all of your '8 under cover then its going to be over 5m in length and if you only use 4 posts then thats a big span without central support and most timber comes in standard lengths under 5m (i.e. my 150x50mm beams are 4.8m in length).
