Old 4th August 2016, 03:05 PM
irelandbuyer irelandbuyer is offline
Default Number plate Bulb woe's
Mannyo,
Same problems here. Both bulbs had blown and the previous owner had tried to remove the screws and flattened the head. It was totally stuck and no amount of drilling would remove it. Very hard to get purchase and proper alignment without removing the whole unit. Anyway, drilled and totally messed up the holder. Purchased the two lights (4E0943021/4E0943022) so will try to fit them. Think i will have to just replace the whole handle as it is corroded now at this stage anyway.
I think on reflection, i would probably have tried to use a hair dryer or the like to heat up the lens, and see if that somehow makes it easier for the screw to become undone. As you mentioned, it is not self tapping so there's no play in it at all should you have a problem...
ANy chance would anybody know the part number for the handle?
