Old 6th May 2010, 01:40 PM
Duffy Duffy is offline
I stripped one of the same caliper retaining bolts on mine last week whilst doing discs and pads.
Drill the head off (I used a 10mm drill then stepped up through 1mm increments to 13mm) and then pull the caliper off, the screw came out by hand thereafter.
Time consuming but straightforward enough in the end.
