Thread: Botang's hole
Old 22nd September 2016, 10:43 AM
Zip's Avatar
Zip Zip is offline
Thumbs up
Couple of updates:
Managed to shove the thin shampoo tube that comes with my VAX in the air vents at the rear and took out another 200 ml or so of water.
Did the Mr Muscle drain gel flush on the main scuttle....bloody miracle stuff! Poured some water in first, then the full 500ml dose of cleaner....then waited. Was a bit sceptical, but after about 10 mins, a raging torrent flooded out of the underside of the car....result. Just rinsed out with boiling water afterwards.
Taken the passenger side transmission tunnel cover off and drained out about 500ml (!) from the drain on that side. Easy to do,as I had that side out when I installed my Dension 100 years ago. What should I stick down through the orange tube to clean it out? Seems very soft and fragile.
How do I get the drivers side out? Do I need to drop the under steering wheel cover?
Thanks,
Zip
