You have access to the bolts from under the wheel arches, have you tried putting the mole grips underneath and holding the captive nut? If that doesn't work then as said a Dremel or some careful drilling them out and just put a normal nut & bolt in to hold the new expansion bottle in place
Nite Blue 3.0L SE Quattro
