Old 4th October 2016, 06:57 PM
MatthewH MatthewH is offline
I've just done a quick log while driving. Not the best test data but it's quite hard to get through the rev range on public roads!
I logged the following fields:
- RPM
- MAF g/s
- Fuel Consumption - Signal (not sure what this is)
- Fuel Consumption - Equivalent (not sure what this is)
- Timing Retardation - Cylinder 1
- Timing Retardation - Cylinder 8
- Lambda Control - Bank 1 Sensor 1
- Sensor Voltage - Bank 1 Sensor 1
- Lambda Control - Bank 2 Sensor 1
- Sensor Voltage - Bank 2 Sensor 1
- Injector Timing ms
Code:
1      October                  23:36:03:40973               Data version: 20130910
ADVMB  4.2L V8/5V      G   0040
       G001                     G003                         G009                      G009                          G020                            G021                            G033                             G033                             G033                             G033                             G101
TIME   Group 1 - Field 0        Group 3 - Field 1            Group 9 - Field 2         Group 9 - Field 3             Group 20 - Field 0              Group 21 - Field 3              Group 33 - Field 0               Group 33 - Field 1               Group 33 - Field 2               Group 33 - Field 3               Group 101 - Field 2
STAMP  Engine Speed - (G28)     Mass Air Flow - Sensor (G70) Fuel Consumption - Signal Fuel Consumption - Equivalent Timing Retardation - Cylinder 1 Timing Retardation - Cylinder 8 Lambda Control - Bank 1 Sensor 1 Sensor Voltage - Bank 1 Sensor 1 Lambda Control - Bank 2 Sensor 1 Sensor Voltage - Bank 2 Sensor 1 Injection Timing
        /min                     g/s        �KW                             �KW                              %                                V                                %                                V                                ms
0.09   640                      4.67                         53584                     26                            0                               0                               -6.3                             1.52                             -7.8                             1.52                             2.87
0.67   640                      4.56                         53825                     26                            0                               0                               -7                               1.52                             -7                               1.54                             2.87
1.26   640                      4.67                         54074                     26                            0                               0                               -6.3                             1.52                             -7                               1.54                             2.87
1.82   640                      4.64                         54327                     26                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
2.42   640                      4.64                         54587                     26                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
3.02   640                      4.61                         54857                     26                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
3.58   680                      4.56                         55117                     28                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
4.16   640                      4.64                         55377                     28                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
4.75   640                      4.64                         55647                     28                            0                               0                               -5.5                             1.54                             -6.3                             1.54                             2.87
5.32   640                      4.5                          55903                     28                            0                               0                               -5.5                             1.54                             -6.3                             1.54                             2.87
5.92   640                      4.72                         56161                     28                            0                               0                               -5.5                             1.56                             -5.5                             1.56                             2.87
6.51   640                      4.61                         56421                     28                            0                               0                               -4.7                             1.56                             -5.5                             1.56                             2.87
7.08   640                      4.64                         56681                     28                            0                               0                               -4.7                             1.54                             -4.7                             1.56                             2.87
7.66   640                      4.61                         56951                     28                            0                               0                               -4.7                             1.54                             -4.7                             1.54                             2.87
8.24   640                      4.58                         57221                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.54                             2.87
8.82   680                      4.58                         57481                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.52                             2.87
9.42   640                      4.64                         57741                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.52                             2.87
10.01  640                      4.67                         58001                     28                            0                               0                               -3.9                             1.52                             -4.7                             1.54                             2.87
10.58  640                      4.67                         58261                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.54                             2.87
11.16  640                      4.72                         58531                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.54                             2.87
11.74  640                      4.64                         58797                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.54                             2.87
12.33  640                      5.11                         59072                     28                            0                               0                               -3.1                             1.56                             -4.7                             1.54                             3.28
12.91  560                      6.89                         59390                     28                            0                               0                               -3.1                             1.56                             -3.9                             1.56                             3.69
13.49  560                      5.58                         59715                     28                            0                               0                               -2.3                             1.56                             -3.1                             1.58                             3.69
14.09  560                      5.33                         60037                     28                            0                               0                               -1.6                             1.56                             -1.6                             1.6                              3.69
14.67  560                      5.17                         60345                     28                            0                               0                               -1.6                             1.56                             -0.8                             1.58                             3.69
15.26  560                      5.39                         60655                     34                            0                               0                               -1.6                             1.54                             0                                1.56                             3.69
15.83  600                      5.61                         61003                     34                            0                               0                               -1.6                             1.52                             0                                1.54                             4.1
16.41  600                      5.64                         61335                     34                            0                               0                               -1.6                             1.54                             0                                1.54                             3.69
16.99  560                      5.5                          61657                     34                            0                               0                               -1.6                             1.54                             0                                1.52                             3.69
17.57  560                      5.33                         61993                     36                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
18.15  560                      5.33                         62301                     36                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
18.73  560                      5.47                         62623                     36                            0                               0                               -2.3                             1.52                             -0.8                             1.52                             3.69
19.34  560                      5.36                         62945                     36                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
19.92  560                      5.39                         63267                     34                            0                               0                               -1.6                             1.54                             -0.8                             1.52                             3.69
20.51  560                      5.33                         63587                     34                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
21.08  560                      5.33                         63892                     34                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
21.66  520                      6.39                         64206                     34                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
22.24  600                      5.67                         64563                     34                            0                               0                               -1.6                             1.54                             0                                1.54                             3.69
22.82  600                      5.67                         64885                     34                            0                               0                               -0.8                             1.56                             0                                1.54                             3.69
23.42  560                      5.44                         65221                     34                            0                               0                               -0.8                             1.54                             0                                1.54                             3.69
24.01  560                      5.42                         7                         34                            0                               0                               -0.8                             1.54                             0                                1.54                             3.69
24.58  560                      5.42                         329                       34                            0                               0                               -0.8                             1.52                             0                                1.52                             3.69
25.17  600                      5.58                         651                       36                            0                               0                               -0.8                             1.54                             0                                1.52                             3.69
25.76  600                      5.39                         1001                      36                            0                               0                               -0.8                             1.54                             0                                1.54                             3.69
26.33  600                      5.28                         1328                      36                            0                               0                               -0.8                             1.52                             0                                1.52                             3.69
26.93  560                      5.72                         1650                      36                            0                               0                               -0.8                             1.52                             0                                1.54                             3.69
27.52  560                      5.31                         1972                      36                            0                               0                               -0.8                             1.52                             0                                1.52                             3.69
28.09  560                      4.97                         2269                      36                            0                               0                               -0.8                             1.52                             0                                1.5                              3.69
28.67  560                      5.14                         2568                      36                            0                               0                               -1.6                             1.5                              0                                1.5                              3.28
29.26  560                      5.08                         2867                      36                            0                               0                               -1.6                             1.5                              -0.8                             1.52                             3.28
29.83  560                      4.92                         3179                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
30.41  560                      5                            3465                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.5                              3.28
31.02  560                      4.86                         3751                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
31.59  560                      5.06                         4050                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.52                             3.28
32.17  560                      5.06                         4349                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
32.77  560                      5.08                         4635                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.54                             3.28
33.33  560                      5.06                         4934                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.54                             3.28
33.91  560                      5.03                         5246                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
34.5   560                      5.08                         5532                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.52                             3.28
35.07  560                      5.11                         5831                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.54                             3.28
35.67  560                      5                            6117                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
36.26  560                      5                            6416                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
36.83  560                      5                            6702                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.52                             3.28
37.41  560                      5.11                         7001                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.54                             3.28
37.99  560                      5.06                         7313                      32                            0                               0                               -0.8                             1.54                             -0.8                             1.54                             3.28
38.57  560                      5.11                         7599                      32                            0                               0                               -1.6                             1.52                             0                                1.54                             3.28
39.17  560                      5.03                         7898                      32                            0                               0                               -0.8                             1.54                             -0.8                             1.52                             3.28
39.76  560                      5.03                         8184                      32                            0                               0                               -0.8                             1.52                             -0.8                             1.54                             3.28
40.33  560                      5.03                         8483                      32                            0                               0                               -0.8                             1.54                             0                                1.54                             3.28
40.91  560                      4.97                         8782                      32                            0                               0                               -0.8                             1.54                             0                                1.54                             3.28
41.49  560                      5.06                         9081                      32                            0                               0                               -0.8                             1.52                             0                                1.52                             3.28
42.07  560                      5.03                         9380                      32                            0                               0                               -0.8                             1.52                             0                                1.52                             3.28
42.67  560                      5.14                         9666                      32                            0                               0                               -0.8                             1.52                             0                                1.52                             3.28
43.26  560                      5                            9965                      32                            0                               0                               -0.8                             1.54                             0                                1.52                             3.28
43.83  560                      5.03                         10264                     32                            0                               0                               -0.8                             1.52                             0                                1.54                             3.28
44.41  560                      5.03                         10550                     32                            0                               0                               -0.8                             1.52                             0                                1.54                             3.28
44.99  520                      6.03                         10845                     32                            0                               0                               -0.8                             1.54                             0                                1.54                             3.69
45.58  600                      5.5                          11200                     32                            0                               0                               -0.8                             1.54                             0                                1.52                             4.1
46.16  600                      5.72                         11551                     32                            0                               0                               0                                1.54                             0                                1.54                             3.69
46.74  520                      7.78                         11957                     34                            0                               0                               0.8                              1.5                              1.6                              1.54                             5.33
47.34  600                      7.36                         12376                     34                            0                               0                               -2.3                             1.48                             0                                1.52                             4.51
47.92  640                      7.86                         12826                     34                            0                               0                               0.8                              1.6                              1.6                              1.58                             4.51
48.51  760                      8.58                         13368                     34                            0                               0                               3.1                              1.62                             3.1                              1.6                              4.92
49.08  880                      10.58                        13980                     50                            0                               0                               4.7                              1.58                             4.7                              1.58                             4.51
49.66  880                      9.72                         14630                     50                            0                               0                               4.7                              1.56                             5.5                              1.54                             4.51
50.24  1040                     15.75                        15449                     50                            0                               0                               0                                1.58                             0                                1.58                             5.74
50.84  1200                     15.64                        16403                     50                            0                               0                               5.5                              1.58                             5.5                              1.6                              5.33
51.42  1280                     17.17                        17384                     86                            0                               0                               3.1                              1.5                              3.1                              1.5                              5.33
52.01  1360                     15.92                        18417                     86                            0                               0                               2.3                              1.48                             2.3                              1.48                             4.92
52.58  1400                     22.31                        19445                     86                            0                               0                               1.6                              1.46                             2.3                              1.48                             4.92
53.16  1680                     24.28                        20857                     86                            0                               0                               1.6                              1.5                              2.3                              1.5                              5.74
53.74  1760                     28.69                        22481                     130                           0                               0                               0.8                              1.5                              0.8                              1.48                             6.15
54.32  1520                     28.28                        24038                     130                           0                               0                               -1.6                             1.46                             0                                1.48                             6.97
54.92  1720                     32.11                        25947                     130                           0                               0                               -1.6                             1.46                             -0.8                             1.46                             7.38
55.51  1800                     27.28                        27790                     130                           0                               0                               -1.6                             1.52                             -1.6                             1.5                              6.97
56.08  1760                     29.14                        29448                     190                           0                               0                               -0.8                             1.54                             -0.8                             1.52                             6.56
56.66  1840                     34.67                        31309                     190                           0                               0                               -1.6                             1.5                              -1.6                             1.48                             6.97
57.24  1840                     29.78                        33139                     190                           0                               0                               -1.6                             1.5                              -1.6                             1.5                              6.15
57.82  1760                     20.56                        34505                     190                           0                               0                               0.8                              1.54                             0                                1.54                             4.92
58.42  1720                     18                           35564                     172                           0                               0                               1.6                              1.54                             1.6                              1.54                             4.1
59.01  1720                     16.5                         36572                     172                           0                               0                               2.3                              1.5                              1.6                              1.5                              4.1
59.58  1680                     16.39                        37508                     172                           0                               0                               1.6                              1.48                             0.8                              1.48                             3.69
60.15  1640                     16.42                        38475                     172                           0                               0                               1.6                              1.48                             0.8                              1.48                             4.1
60.76  1640                     21.17                        39534                     108                           0                               0                               -0.8                             1.44                             -0.8                             1.46                             4.1
61.32  1760                     24.89                        40950                     108                           0                               0                               0                                1.52                             -0.8                             1.5                              5.74
61.92  1800                     28.83                        42434                     108                           0                               0                               -1.6                             1.48                             -2.3                             1.48                             5.33
62.52  1920                     27.19                        44010                     108                           0                               0                               -1.6                             1.5                              -2.3                             1.52                             5.74
63.08  1560                     23.03                        45453                     162                           0                               0                               -2.3                             1.46                             -1.6                             1.5                              5.74
63.66  1560                     24.67                        46815                     162                           0                               0                               -0.8                             1.54                             0                                1.54                             6.15
64.26  1640                     26.33                        48386                     162                           0                               0                               -0.8                             1.52                             0.8                              1.5                              6.15
64.82  1600                     21.67                        49868                     162                           0                               0                               -1.6                             1.48                             0                                1.48                             6.15
65.42  1320                     16.08                        50860                     162                           0                               0                               0                                1.58                             0                                1.56                             4.51
66.01  1400                     15.89                        51741                     98                            0                               0                               2.3                              1.56                             2.3                              1.58                             4.51
66.58  1400                     16.75                        52661                     98                            0                               0                               2.3                              1.52                             3.1                              1.52                             4.51
67.17  1440                     20.42                        53661                     98                            0                               0                               1.6                              1.46                             2.3                              1.48                             4.51
67.76  1440                     18.58                        54752                     98                            0                               0                               0.8                              1.46                             1.6                              1.48                             4.92
68.33  1480                     19.22                        55847                     72                            0                               0                               -1.6                             1.46                             0                                1.48                             5.33
68.91  1480                     17.83                        56975                     72                            0                               0                               -1.6                             1.52                             -0.8                             1.5                              4.92
69.49  1480                     17.83                        58019                     72                            0                               0                               -1.6                             1.5                              -0.8                             1.5                              4.92
70.07  1520                     16.86                        59050                     72                            0                               0                               -1.6                             1.48                             -0.8                             1.52                             4.51
70.67  1480                     16.08                        59994                     78                            0                               0                               -0.8                             1.52                             0                                1.54                             4.51
71.26  1520                     11.39                        60869                     78                            0                               0                               -0.8                             1.52                             0                                1.52                             4.1
71.83  1440                     10.69                        61536                     78                            0                               0                               1.6                              1.58                             1.6                              1.56                             3.28
72.41  1440                     10.39                        62152                     78                            0                               0                               3.9                              1.58                             3.9                              1.58                             3.28
72.99  1440                     9.86                         62808                     54                            0                               0                               4.7                              1.54                             5.5                              1.56                             3.69
73.57  1400                     9.42                         63418                     54                            0                               0                               4.7                              1.54                             4.7                              1.52                             3.28
74.15  1400                     15.86                        64132                     54                            0                               0                               6.3                              1.54                             6.3                              1.52                             3.69
74.73  1440                     16.22                        65070                     54                            0                               0                               4.7                              1.48                             4.7                              1.48                             4.51
75.34  1440                     16.5                         486                       56                            0                               0                               3.1                              1.48                             3.9                              1.48                             4.51
75.92  1440                     16.47                        1438                      56                            0                               0                               3.9                              1.5                              3.9                              1.5                              4.51
76.51  1440                     16.78                        2390                      56                            0                               0                               3.9                              1.52                             4.7                              1.52                             4.51
77.08  1440                     15.89                        3327                      56                            0                               0                               4.7                              1.54                             5.5                              1.54                             4.51
77.66  1440                     7.53                         4181                      68                            0                               0                               5.5                              1.54                             6.3                              1.54                             4.1
78.24  1360                     10.31                        4781                      68                            0                               0                               7.8                              1.58                             7.8                              1.56                             3.28
78.84  1320                     10.28                        5365                      68                            0                               0                               9.4                              1.56                             9.4                              1.56                             3.28
79.43  1320                     9.75                         5960                      68                            0                               0                               10.2                             1.54                             10.2                             1.54                             3.28
80.02  1280                     9.22                         6532                      44                            0                               0                               10.2                             1.52                             9.4                              1.52                             3.28
80.59  1280                     9.03                         7081                      44                            0                               0                               10.9                             1.54                             10.2                             1.52                             3.28
81.17  1280                     13.97                        7708                      44                            0                               0                               11.7                             1.52                             11.7                             1.54                             3.69
81.76  1320                     13.31                        8504                      44                            0                               0                               9.4                              1.44                             9.4                              1.46                             4.1
82.33  1320                     13.19                        9274                      48                            0                               0                               9.4                              1.48                             8.6                              1.46                             4.1
82.93  1320                     13.39                        10105                     48                            0                               0                               8.6                              1.48                             7.8                              1.48                             4.1
83.52  1320                     15.47                        10927                     48                            0                               0                               8.6                              1.5                              7.8                              1.5                              4.1
84.09  1320                     14.97                        11811                     48                            0                               0                               7.8                              1.5                              7                                1.5                              4.51
84.67  1320                     14.72                        12695                     62                            0                               0                               7                                1.48                             7                                1.48                             4.51
85.26  1320                     13.28                        13595                     62                            0                               0                               6.3                              1.48                             6.3                              1.48                             4.51
85.83  1280                     10.06                        14255                     62                            0                               0                               7                                1.54                             6.3                              1.52                             3.69
86.43  1280                     10.36                        14855                     62                            0                               0                               8.6                              1.54                             7                                1.54                             3.28
87.02  1280                     10.25                        15455                     62                            0                               0                               6.3                              1.52                             10.2                             1.56                             3.28
87.59  1200                     9.42                         16031                     50                            0                               0                               11.7                             1.54                             6.3                              1.54                             3.28
88.17  1200                     9.06                         16595                     50                            0                               0                               0                                1.54                             0                                1.5                              3.28
88.76  1040                     8.06                         17099                     50                            0                               0                               -2.3                             1.54                             3.1                              1.56                             3.28
89.33  840                      6.81                         17484                     50                            0                               0                               3.1                              1.54                             -1.6                             1.52                             3.28
89.92  760                      6.53                         17869                     36                            0                               0                               3.9                              1.56                             -1.6                             1.58                             3.69
90.52  640                      8.36                         18295                     36                            0                               0                               2.3                              1.56                             2.3                              1.56                             4.92
91.08  720                      7.03                         18745                     36                            0                               0                               4.7                              1.54                             -0.8                             1.54                             4.51
91.66  640                      7.11                         19147                     36                            0                               0                               4.7                              1.54                             0                                1.58                             4.1
92.26  680                      7.42                         19595                     30                            0                               0                               0.8                              1.56                             6.3                              1.56                             4.51
92.82  640                      15.61                        20048                     30                            0                               0                               6.3                              1.58                             1.6                              1.56                             4.51
93.42  840                      8.19                         20606                     30                            0                               0                               0.8                              1.48                             4.7                              1.52                             4.92
94.01  800                      7.92                         21096                     30                            0                               0                               1.6                              1.54                             6.3                              1.54                             4.1
94.58  920                      22.14                        21794                     36                            0                               0                               0                                1.48                             0                                1.48                             4.92
95.17  1240                     18.56                        22866                     36                            0                               0                               3.1                              1.6                              5.5                              1.58                             5.74
95.76  1320                     20.5                         23988                     36                            0                               0                               0                                1.4                              5.5                              1.56                             5.74
96.33  1400                     27.72                        25201                     36                            0                               0                               4.7                              1.52                             0                                1.46                             5.74
96.91  1600                     26.81                        26643                     82                            0                               0                               0                                1.56                             5.5                              1.48                             6.15
97.49  1760                     29.53                        28411                     82                            0                               0                               3.1                              1.42                             -0.8                             1.54                             6.97
98.07  1880                     31.94                        30222                     82                            0                               0                               2.3                              1.5                              0                                1.48                             6.56
98.66  2160                     68.81                        32806                     82                            0                               0                               0.8                              1.56                             1.6                              1.56                             8.61
99.27  2240                     72.03                        36614                     162                           0                               0                               0.8                              1.44                             1.6                              1.44                             12.3
99.84  2440                     61.11                        41118                     162                           0                               3                               0                                1.02                             0                                1.08                             13.53
100.42 1800                     10.97                        42308                     162                           0                               0                               2.3                              1.66                             1.6                              1.62                             3.28
101.01 1560                     11.08                        42957                     162                           0                               0                               7.8                              1.56                             7                                1.62                             2.87
101.58 1280                     9.42                         43513                     148                           0                               0                               8.6                              1.56                             3.1                              1.54                             2.87
102.16 1320                     6.22                         44001                     148                           0                               0                               3.9                              1.52                             8.6                              1.54                             2.87
102.77 1080                     15.92                        44378                     148                           0                               0                               4.7                              1.66                             0                                1.64                             2.46
103.34 1320                     9.75                         44870                     148                           0                               0                               2.3                              1.54                             9.4                              1.6                              2.87
103.92 1360                     9.58                         45457                     34                            0                               0                               1.6                              1.52                             8.6                              1.54                             3.28
104.51 1400                     7                            45988                     34                            0                               0                               8.6                              1.56                             3.9                              1.52                             2.87
105.08 1320                     6.94                         46432                     34                            0                               0                               3.9                              1.56                             10.2                             1.58                             2.46
105.66 1280                     9.67                         46897                     34                            0                               0                               7.8                              1.6                              14.8                             1.6                              2.87
106.27 1280                     9.33                         47447                     36                            0                               0                               11.7                             1.54                             8.6                              1.5                              3.28
106.84 1200                     8.89                         47975                     36                            0                               0                               7                                1.5                              12.5                             1.5                              3.28
107.42 1120                     8.42                         48463                     36                            0                               0                               6.3                              1.48                             12.5                             1.48                             3.28
108.01 1000                     7.67                         48955                     36                            0                               0                               9.4                              1.44                             5.5                              1.42                             3.69
108.58 1160                     9.03                         49461                     36                            0                               0                               3.1                              1.44                             8.6                              1.48                             3.28
109.16 960                      7.81                         49949                     36                            0                               0                               7                                1.46                             3.1                              1.4                              3.28
109.74 800                      7.11                         50337                     36                            0                               0                               5.5                              1.42                             0.8                              1.42                             3.28
110.34 720                      6.19                         50714                     36                            0                               0                               0                                1.48                             5.5                              1.48                             3.69
110.93 720                      5.78                         51172                     36                            0                               0                               5.5                              1.5                              0                                1.42                             4.51
111.52 680                      8                            51577                     30                            0                               0                               4.7                              1.48                             -1.6                             1.48                             4.1
112.09 680                      7.17                         51993                     30                            0                               0                               0.8                              1.54                             4.7                              1.54                             4.51
112.67 640                      8.06                         52449                     30                            0                               0                               6.3                              1.56                             0                                1.56                             4.1
113.26 680                      7.83                         52948                     30                            0                               0                               0.8                              1.5                              5.5                              1.56                             4.92
113.83 800                      32.5                         53753                     32                            0                               0                               0                                1.42                             0                                1.42                             6.56
114.43 1600                     30.75                        55495                     32                            0                               0                               2.3                              1.5                              -1.6                             1.5                              8.61
115.02 1800                     34.08                        57469                     32                            0                               0                               -1.6                             1.5                              1.6                              1.42                             7.38
115.59 2040                     37.72                        59591                     32                            0                               0                               -2.3                             1.5                              2.3                              1.58                             7.38
116.17 1720                     32.5                         61524                     130                           0                               0                               2.3                              1.48                             -1.6                             1.52                             7.38
116.76 1920                     48.86                        63985                     130                           0                               0                               -2.3                             1.56                             1.6                              1.44                             9.02
117.33 2120                     49.75                        1212                      130                           0                               0                               -1.6                             1.46                             3.1                              1.56                             9.02
117.91 2240                     51.28                        4198                      130                           0                               0                               1.6                              1.46                             -1.6                             1.44                             9.43
118.52 1960                     55.75                        7051                      192                           0                               0                               0.8                              1.52                             1.6                              1.46                             9.43
119.08 2160                     66.06                        10545                     192                           0                               0                               3.1                              1.46                             -2.3                             1.56                             11.07
119.66 2280                     67.94                        14489                     192                           3                               3                               1.6                              1.46                             -1.6                             1.46                             12.3
120.26 2240                     68.08                        18424                     192                           3                               3                               -2.3                             1.52                             0.8                              1.46                             11.89
120.83 2040                     46.53                        21880                     268                           3                               3                               0                                1.32                             0                                1.34                             11.48
121.41 1640                     10.03                        23013                     268                           0                               0                               2.3                              1.62                             1.6                              1.58                             3.69
121.99 1280                     9.19                         23572                     268                           0                               0                               6.3                              1.62                             5.5                              1.64                             3.28
122.57 1040                     7.31                         24051                     268                           0                               0                               6.3                              1.66                             1.6                              1.64                             3.28
123.17 1000                     8.03                         24500                     62                            0                               0                               7                                1.56                             3.1                              1.6                              3.28
123.76 880                      6.64                         24918                     62                            0                               0                               1.6                              1.54                             7                                1.54                             3.28
124.33 960                      6.69                         25322                     62                            0                               0                               7                                1.56                             2.3                              1.52                             3.28
124.92 840                      6.47                         25715                     62                            0                               0                               3.9                              1.58                             8.6                              1.6                              3.28
125.51 960                      7.83                         26124                     30                            0                               0                               4.7                              1.56                             9.4                              1.58                             3.28
126.08 800                      6.06                         26512                     30                            0                               0                               9.4                              1.52                             4.7                              1.52                             3.28
126.66 680                      15.19                        26867                     30                            0                               0                               3.9                              1.5                              9.4                              1.52                             3.28
127.24 680                      5.94                         27306                     30                            0                               0                               2.3                              1.46                             7.8                              1.42                             4.1
127.82 680                      6.28                         27707                     28                            0                               0                               6.3                              1.46                             1.6                              1.46                             4.1
128.4  640                      9.83                         28104                     28                            0.8                             0.8                             0.8                              1.44                             6.3                              1.5                              4.1
129.01 680                      7.33                         28576                     28                            0.8                             0.8                             3.9                              1.46                             0.8                              1.46                             4.51
129.58 680                      8.03                         28998                     28                            0                               0                               2.3                              1.54                             2.3                              1.5                              4.51
130.16 920                      11.08                        29773                     28                            0                               0                               0                                1.4                              0                                1.34                             6.15
130.74 1200                     17.33                        30635                     38                            0                               0                               4.7                              1.58                             3.9                              1.56                             4.92
131.32 1560                     28.06                        32261                     38                            0                               0                               1.6                              1.5                              -1.6                             1.52                             7.38
131.9  1800                     28.94                        33946                     38                            0                               0                               -2.3                             1.52                             2.3                              1.46                             6.56
132.51 1880                     31.53                        35751                     38                            0                               0                               3.1                              1.48                             -1.6                             1.58                             6.56
133.09 1680                     28.17                        37430                     112                           0                               0                               3.1                              1.56                             -2.3                             1.46                             6.97
133.67 1760                     30.69                        39169                     112                           0                               0                               -2.3                             1.48                             1.6                              1.48                             6.97
134.26 1880                     32.22                        40975                     112                           0                               0                               0.8                              1.42                             -2.3                             1.56                             6.56
134.83 2040                     37.22                        42995                     112                           0                               0                               -3.1                             1.54                             1.6                              1.4                              6.97
135.41 1800                     33.58                        45063                     134                           0                               0                               -2.3                             1.44                             2.3                              1.54                             7.38
135.99 1800                     34.5                         47021                     134                           0                               0                               1.6                              1.44                             -2.3                             1.5                              7.38
136.57 1800                     35.03                        49011                     134                           0                               0                               -2.3                             1.54                             1.6                              1.44                             7.38
137.17 1680                     30.5                         50860                     134                           0                               0                               -3.1                             1.44                             2.3                              1.56                             7.38
137.76 1680                     9.06                         52162                     140                           0                               0                               2.3                              1.62                             -2.3                             1.52                             4.92
138.33 1280                     10.53                        52776                     140                           0                               0                               1.6                              1.62                             7                                1.6                              3.28
138.92 1280                     10.11                        53388                     140                           0                               0                               3.1                              1.58                             8.6                              1.56                             3.28
139.51 1320                     7.58                         53971                     140                           0                               0                               7.8                              1.54                             3.9                              1.48                             3.28
140.08 1200                     6.31                         54376                     46                            0                               0                               3.9                              1.56                             9.4                              1.58                             2.46
140.66 1120                     9.19                         54780                     46                            0                               0                               10.9                             1.66                             5.5                              1.68                             2.46
141.24 1320                     9.67                         55416                     46                            0                               0                               5.5                              1.4                              2.3                              1.42                             3.28
141.82 1320                     10.14                        55993                     46                            0                               0                               1.6                              1.48                             6.3                              1.5                              3.28
142.42 1320                     9.11                         56575                     38                            0                               0                               7                                1.52                             2.3                              1.48                             3.28
143.01 1360                     8.86                         57095                     38                            0                               0                               7.8                              1.52                             2.3                              1.5                              2.87
143.58 1360                     6.89                         57616                     38                            0                               0                               3.1                              1.48                             7.8                              1.52                             2.87
144.16 1240                     6.22                         58008                     38                            0                               0                               8.6                              1.54                             4.7                              1.52                             2.46
144.74 1200                     5.67                         58358                     32                            0                               0                               0                                1.68                             0                                1.62                             2.46
145.32 1320                     6.89                         58722                     32                            0                               0                               0                                2.58                             0                                2.76                             2.05
145.93 1280                     6.44                         59002                     32                            0                               0                               0                                3.32                             0                                3.5                              2.05
146.52 1280                     6.42                         59002                     32                            0                               0                               0                                3.8                              0                                3.96                             0
147.09 1320                     6.64                         59002                     12                            0                               0                               0                                4.2                              0                                3.92                             0
147.67 1280                     6.25                         59002                     12                            0                               0                               0                                4.02                             0                                4.26                             0
148.26 1240                     6.39                         59002                     12                            0                               0                               0                                4.28                             0                                4.08                             0
148.82 1240                     6.19                         59002                     12                            0                               0                               0                                4.32                             0                                4.08                             0
149.41 1240                     6.31                         59002                     0                             0                               0                               0                                4.12                             0                                4.28                             0
150.02 1200                     5.81                         59002                     0                             0                               0                               0                                4.3                              0                                4.12                             0
150.58 1120                     5.19                         59073                     0                             0                               0                               0                                4                                0                                4.1                              0
151.16 1080                     9.42                         59543                     0                             0                               0                               0                                2.34                             0                                2.64                             3.28
151.74 1160                     9.11                         60059                     0                             0                               0                               0                                1.94                             0                                2.12                             3.28
152.32 1160                     9.06                         60606                     20                            0                               0                               0                                1.78                             0                                1.8                              3.28
152.9  1000                     8.39                         61098                     20                            0                               0                               7.8                              1.66                             3.9                              1.68                             3.28
153.51 880                      6.97                         61539                     20                            0                               0                               2.3                              1.54                             7.8                              1.54                             3.69
154.08 760                      5.97                         61911                     20                            0                               0                               5.5                              1.5                              1.6                              1.5                              3.28
154.67 680                      6.89                         62327                     32                            0                               0                               5.5                              1.48                             1.6                              1.52                             4.51
155.26 680                      6.39                         62733                     32                            0                               0                               0                                1.48                             5.5                              1.48                             4.1
155.83 680                      6.44                         63111                     32                            0                               0                               4.7                              1.5                              0.8                              1.48                             3.69
156.41 840                      19.56                        63590                     32                            0                               0                               0                                1.54                             0                                1.5                              3.69
156.99 1440                     35.92                        65194                     34                            0                               0                               0                                1.54                             0                                1.56                             7.79
157.59 1880                     43.31                        2090                      34                            0                               0                               0.8                              1.48                             -0.8                             1.52                             9.02
158.17 2080                     56                           4971                      34                            0                               0                               -1.6                             1.54                             2.3                              1.46                             9.84
158.76 2280                     58.19                        8230                      34                            0                               0                               -0.8                             1.44                             2.3                              1.54                             10.25
159.33 2280                     58.11                        11667                     204                           0                               0                               0.8                              1.48                             -3.1                             1.56                             10.25
159.91 2160                     55.64                        14777                     204                           0                               3                               0.8                              1.56                             0                                1.48                             10.25
160.49 2320                     68.11                        18495                     204                           0                               3                               0                                1.34                             0                                1.36                             11.48
161.08 2080                     8.61                         20952                     204                           0                               0                               0                                1.26                             0                                1.26                             6.56
161.66 1480                     10.75                        21575                     204                           0                               0                               0.8                              1.56                             0                                1.56                             2.87
162.24 1320                     9.64                         22095                     204                           0                               0                               5.5                              1.58                             1.6                              1.6                              2.87
162.84 1320                     9.53                         22615                     204                           0                               0                               7                                1.56                             2.3                              1.56                             2.87
163.42 1280                     6.33                         23043                     204                           0                               0                               0.8                              1.5                              7                                1.56                             2.46
164.01 1040                     7.78                         23418                     34                            0                               0                               7.8                              1.66                             1.6                              1.64                             2.87
164.58 1280                     9.28                         23936                     34                            0                               0                               4.7                              1.48                             1.6                              1.54                             2.87
165.16 1280                     9                            24457                     34                            0                               0                               0.8                              1.5                              7                                1.54                             2.87
165.74 1360                     14.97                        25194                     34                            0                               0                               7.8                              1.52                             3.1                              1.48                             4.51
166.34 1360                     17.67                        26168                     46                            0                               0                               0                                1.58                             3.9                              1.54                             4.92
166.93 1360                     17.67                        27244                     46                            0                               0                               0.8                              1.46                             5.5                              1.56                             5.33
167.52 1320                     7.44                         28223                     46                            0                               0                               4.7                              1.48                             -0.8                             1.38                             5.33
168.09 1280                     9.28                         28833                     46                            0                               0                               2.3                              1.56                             5.5                              1.56                             3.28
168.67 1280                     29.28                        29646                     62                            0                               0                               1.6                              1.26                             1.6                              1.28                             4.1
169.26 1440                     28.42                        31345                     62                            0                               0                               0                                1.5                              0                                1.48                             7.38
169.83 1320                     24.36                        32812                     62                            0                               0                               -1.6                             1.5                              1.6                              1.48                             7.38
170.43 1400                     20.92                        34048                     62                            0                               0                               -0.8                             1.48                             3.9                              1.6                              6.15
171.02 1400                     21.28                        35311                     62                            0                               0                               4.7                              1.58                             0                                1.5                              6.15
171.59 1440                     25.69                        36754                     102                           0                               0                               -1.6                             1.52                             3.1                              1.44                             6.97
172.17 1480                     29.33                        38328                     102                           0                               0                               1.6                              1.42                             -1.6                             1.54                             7.79
172.76 1440                     11.58                        39927                     102                           0                               0                               0                                1.52                             -3.9                             1.38                             7.79
173.33 1400                     10.56                        40635                     102                           0                               0                               0.8                              1.6                              5.5                              1.64                             3.28
173.93 1520                     33.06                        41808                     96                            0                               0                               3.1                              1.42                             -0.8                             1.52                             5.74
174.52 1440                     25.58                        43317                     96                            0                               0                               3.1                              1.52                             -1.6                             1.34                             6.97
175.09 1200                     23.58                        44661                     96                            0                               0                               -0.8                             1.48                             3.9                              1.56                             7.38
175.67 1160                     22.94                        45980                     96                            0                               0                               3.9                              1.42                             -0.8                             1.5                              7.38
176.26 1160                     23.14                        47343                     98                            0                               0                               3.1                              1.54                             -0.8                             1.42                             7.79
176.83 1160                     22.56                        48670                     98                            0                               0                               -1.6                             1.44                             3.9                              1.56                             7.38
177.43 1160                     21.28                        49922                     98                            0                               0                               3.9                              1.52                             -0.8                             1.5                              6.97
178.02 1200                     4.78                         51027                     98                            0                               0                               -3.9                             1.42                             1.6                              1.46                             6.97
178.58 1120                     8.56                         51557                     88                            0                               0                               -1.6                             1.58                             3.9                              1.58                             3.28
179.16 1240                     16.75                        52378                     88                            0                               0                               3.9                              1.56                             -1.6                             1.52                             5.33
179.76 1240                     18.08                        53429                     88                            0                               0                               0                                1.56                             3.9                              1.5                              5.33
180.32 1200                     17.31                        54429                     88                            0                               0                               0                                1.48                             4.7                              1.56                             5.74
180.92 1160                     16.64                        55396                     64                            0                               0                               5.5                              1.58                             0                                1.48                             5.74
181.51 1200                     14.58                        56350                     64                            0                               0                               0.8                              1.48                             6.3                              1.54                             5.33
182.08 1120                     12.17                        57101                     64                            0                               0                               7                                1.56                             2.3                              1.56                             4.51
182.67 1160                     7.94                         57815                     64                            0                               0                               2.3                              1.58                             -2.3                             1.52                             4.51
183.26 1080                     8.08                         58340                     58                            0                               0                               0.8                              1.58                             5.5                              1.6                              3.28
183.83 1080                     7.58                         58819                     58                            0                               0                               5.5                              1.56                             0.8                              1.54                             3.28
184.41 1080                     7.69                         59274                     58                            0                               0                               6.3                              1.56                             1.6                              1.58                             3.28
184.99 1080                     8.03                         59704                     58                            0                               0                               2.3                              1.56                             7.8                              1.6                              2.87
185.57 1160                     12.92                        60409                     36                            0                               0                               0                                1.52                             0                                1.52                             4.51
186.15 1200                     22.5                         61330                     36                            0                               0                               4.7                              1.6                              -1.6                             1.54                             4.51
186.76 1160                     6.11                         62238                     36                            0                               0                               -3.1                             1.48                             2.3                              1.56                             5.74
187.33 1040                     14.56                        62786                     36                            0                               0                               0                                1.6                              0                                1.6                              3.28
187.91 1320                     25.03                        64028                     64                            0                               0                               0                                1.46                             0                                1.46                             7.38
188.49 1200                     23.72                        65485                     64                            0                               0                               -1.6                             1.5                              1.6                              1.56                             7.79
189.08 1120                     21.89                        1280                      64                            0                               3                               2.3                              1.48                             -2.3                             1.5                              7.79
189.66 1120                     11.86                        2395                      64                            0                               3                               -2.3                             1.58                             3.1                              1.54                             6.56
190.24 1200                     14.36                        3242                      88                            0                               3                               0.8                              1.56                             6.3                              1.6                              4.92
190.82 1120                     8.64                         3834                      88                            0                               0                               4.7                              1.62                             0                                1.6                              3.69
191.41 1120                     8.86                         4365                      88                            0                               0                               0.8                              1.52                             7                                1.58                             3.28
191.99 1120                     8.22                         4849                      88                            0                               0                               0.8                              1.56                             7.8                              1.54                             3.28
192.59 1120                     7.67                         5305                      88                            0                               0                               6.3                              1.56                             3.9                              1.52                             2.87
193.17 1120                     7.25                         5735                      36                            0                               0                               2.3                              1.52                             9.4                              1.52                             2.87
193.76 1080                     7.22                         6165                      36                            0                               0                               7                                1.54                             4.7                              1.5                              2.87
194.33 1080                     7.17                         6595                      36                            0                               0                               7.8                              1.54                             4.7                              1.5                              2.87
194.91 1080                     7.19                         7035                      36                            0                               0                               3.1                              1.52                             10.2                             1.54                             2.87
195.49 1080                     6.94                         7455                      30                            0                               0                               8.6                              1.54                             5.5                              1.5                              2.87
196.1  1080                     6.28                         7885                      30                            0                               0                               8.6                              1.52                             5.5                              1.48                             2.87
196.68 1040                     7.03                         8295                      30                            0                               0                               3.1                              1.5                              10.2                             1.48                             2.87
197.27 1040                     6.94                         8715                      30                            0                               0                               8.6                              1.54                             5.5                              1.48                             2.87
197.84 1040                     7.03                         9125                      30                            0                               0                               8.6                              1.52                             5.5                              1.5                              2.87
198.42 1080                     63                           10115                     30                            4.5                             4.5                             0                                1.16                             0                                1.16                             4.51
199.01 2400                     88                           15121                     30                            9                               6                               0                                1                                0                                0.98                             14.35
199.58 3560                     138.75                       23803                     30                            9                               6                               -7.8                             1                                -5.5                             1.08                             17.63
200.18 3960                     160.94                       33233                     330                           9                               5.3                             -7                               1.1                              -4.7                             1.04                             16.4
200.78 4360                     170.44                       43956                     330                           12                              11.3                            0                                0.76                             0                                0.86                             16.4
201.37 4320                     32.72                        49958                     330                           0                               0                               0                                0.86                             0                                1                                5.74
201.95 2800                     16.58                        51128                     330                           0                               0                               0                                1.12                             0                                1.18                             2.46
202.54 2720                     15.31                        51995                     432                           0                               0                               -4.7                             1.56                             -7.8                             1.48                             2.46
203.11 2520                     14.31                        52749                     432                           0                               0                               -6.3                             1.54                             0                                1.54                             2.46
203.71 2320                     12.89                        53427                     432                           0                               0                               0                                1.52                             0                                1.62                             2.46
204.3  2120                     12.25                        54091                     432                           0                               0                               0                                2.9                              0                                2.86                             2.46
204.87 1960                     11.53                        54725                     50                            0                               0                               0                                3.94                             0                                3.2                              2.46
205.45 1840                     9.86                         55301                     50                            0                               0                               0                                4.04                             0                                3.48                             2.46
206.04 1760                     8.58                         55389                     50                            0                               0                               0                                4.26                             0                                3.92                             0
206.61 1680                     8.42                         55400                     50                            0                               0                               0                                3.92                             0                                3.96                             0
207.19 1680                     17.58                        56194                     26                            0                               0                               0                                1.68                             0                                1.88                             3.69
207.8  1680                     14.86                        57121                     26                            0                               0                               0                                1.48                             0                                1.54                             4.1
208.37 1640                     11.47                        57847                     26                            0                               0                               -4.7                             1.44                             3.1                              1.52                             3.28
208.95 1560                     10.44                        58479                     26                            0                               0                               0                                1.48                             -3.1                             1.46                             2.87
209.54 1200                     7.5                          58971                     52                            0                               0                               -6.3                             1.5                              1.6                              1.54                             2.87
210.11 1120                     5.22                         59356                     52                            0                               0                               -0.8                             1.6                              3.9                              1.6                              2.46
210.69 1200                     8.86                         59841                     52                            0                               0                               2.3                              1.46                             -1.6                             1.44                             3.28
211.3  1160                     8.89                         60330                     52                            0                               0                               -4.7                             1.42                             2.3                              1.5                              2.87
211.87 1160                     8.39                         60790                     32                            0                               0                               -3.9                             1.52                             3.9                              1.52                             2.87
212.45 1160                     8.19                         61240                     32                            0                               0                               1.6                              1.54                             -0.8                             1.48                             2.87
213.04 1160                     8                            61690                     32                            0                               0                               -3.1                             1.5                              3.9                              1.52                             2.87
213.61 1120                     7.17                         62148                     32                            0                               0                               -3.9                             1.5                              3.9                              1.48                             2.87
214.19 1120                     7.39                         62544                     32                            0                               0                               0.8                              1.5                              -1.6                             1.46                             2.87
214.8  1080                     6.94                         62922                     32                            0                               0                               -4.7                             1.48                             3.9                              1.5                              2.87
215.37 960                      8.08                         63301                     32                            0                               0                               0                                1.5                              -1.6                             1.44                             2.87
215.95 960                      6.64                         63672                     32                            0                               0                               -1.6                             1.46                             -3.9                             1.4                              2.87
216.54 960                      7.67                         64078                     32                            0                               0                               -5.5                             1.5                              1.6                              1.5                              2.87
217.11 840                      6.67                         64444                     28                            0                               0                               -1.6                             1.5                              -4.7                             1.42                             2.87
217.69 720                      9.06                         64789                     28                            0                               0                               -1.6                             1.5                              -4.7                             1.48                             3.28
218.28 720                      5.81                         65144                     28                            0                               0                               -6.3                             1.56                             0.8                              1.5                              3.28
218.85 680                      6.44                         65463                     28                            0                               0                               0                                1.58                             -3.9                             1.52                             3.28
219.45 680                      5.78                         266                       24                            0                               0                               -3.9                             1.58                             1.6                              1.54                             3.69
220.04 680                      5.83                         614                       24                            9                               8.3                             0.8                              1.58                             0                                1.54                             3.28
220.6  1120                     21.92                        1630                      24                            6                               5.3                             0                                1.48                             0                                1.48                             8.61
221.18 1480                     25.89                        3213                      24                            6                               5.3                             -3.1                             1.52                             0.8                              1.48                             7.38
221.78 1480                     27                           4747                      68                            6                               5.3                             -3.1                             1.44                             1.6                              1.58                             6.97
222.34 1560                     28.14                        6450                      68                            6                               5.3                             1.6                              1.52                             -2.3                             1.5                              7.38
222.92 1600                     27.89                        8118                      68                            6                               5.3                             -3.1                             1.56                             1.6                              1.44                             7.38
223.53 1440                     9.39                         9273                      68                            0                               0                               -5.5                             1.48                             0                                1.5                              4.51
224.1  1160                     10.61                        9871                      102                           0                               0                               4.7                              1.66                             0                                1.6                              3.69
224.68 1120                     10.17                        10456                     102                           0                               0                               -1.6                             1.54                             3.1                              1.58                             3.69
225.27 1040                     9.03                         11002                     102                           0                               0                               2.3                              1.48                             -2.3                             1.46                             3.69
225.84 960                      7.69                         11493                     102                           0                               0                               0.8                              1.44                             -4.7                             1.44                             3.69
226.42 880                      7.17                         11913                     38                            0                               0                               -3.9                             1.52                             0                                1.5                              3.28
227.03 760                      6.61                         12285                     38                            0                               0                               1.6                              1.56                             -3.9                             1.54                             3.28
227.6  680                      6.25                         12609                     38                            0                               0                               2.3                              1.54                             -3.1                             1.56                             3.28
228.18 680                      6.19                         12937                     38                            0                               0                               -2.3                             1.56                             2.3                              1.54                             3.69
228.77 680                      6.69                         13301                     26                            0                               0                               3.1                              1.56                             -1.6                             1.54                             3.69
229.34 680                      6.53                         13693                     26                            0                               0                               -1.6                             1.54                             3.1                              1.54                             3.69
229.92 640                      7.5                          14069                     26                            0                               0                               -1.6                             1.54                             3.9                              1.52                             4.1
230.53 680                      6.56                         14481                     26                            0                               0                               3.1                              1.52                             -1.6                             1.5                              4.1
231.1  760                      7.92                         14899                     28                            0                               0                               -2.3                             1.52                             3.1                              1.52                             4.1
231.68 800                      6.78                         15339                     28                            0                               0                               -2.3                             1.54                             3.9                              1.5                              3.69
232.27 680                      36.97                        15844                     28                            0                               0                               0                                1.34                             0                                1.2                              3.69
232.84 1160                     23.39                        17012                     28                            0                               0                               -2.3                             1.52                             1.6                              1.52                             6.56
233.42 1200                     4.39                         18061                     56                            0                               0                               -3.1                             1.48                             1.6                              1.46                             6.15
234.03 760                      15.47                        18582                     56                            0                               0                               3.1                              1.58                             -3.1                             1.54                             4.1
234.6  760                      7.25                         19109                     56                            0                               0                               -1.6                             1.52                             2.3                              1.56                             4.51
235.18 720                      7.69                         19562                     56                            0                               0                               2.3                              1.52                             -2.3                             1.5                              4.1
235.77 720                      7.61                         19997                     56                            0                               0                               2.3                              1.52                             -3.1                             1.52                             4.1
236.34 720                      7.36                         20432                     34                            0                               0                               -2.3                             1.52                             3.1                              1.54                             4.1
236.92 680                      7.06                         20852                     34                            0                               0                               3.1                              1.56                             -1.6                             1.52                             4.1
237.53 800                      5.64                         21347                     34                            0                               0                               2.3                              1.48                             -0.8                             1.5                              4.51
238.1  720                      9.78                         21777                     34                            0                               0                               -3.1                             1.54                             3.9                              1.5                              4.1
238.68 560                      6.86                         22203                     32                            0                               0                               3.1                              1.54                             0                                1.52                             4.92
239.27 560                      7.94                         22646                     32                            0                               0                               0                                1.44                             1.6                              1.48                             5.74
239.84 920                      12.47                        23434                     32                            0                               0                               0                                1.4                              0                                1.32                             6.97
240.42 920                      10.58                        24208                     32                            0                               0                               1.6                              1.52                             -3.1                             1.46                             5.33
241.01 880                      14.56                        25014                     44                            0                               0                               -3.1                             1.48                             2.3                              1.46                             6.97
241.58 1200                     18.42                        26072                     44                            0                               0                               -1.6                             1.5                              3.1                              1.6                              6.15
242.18 1360                     19.03                        27222                     44                            0                               0                               0.8                              1.5                              -4.7                             1.42                             5.74
242.77 1480                     21.19                        28395                     44                            0                               0                               0                                1.56                             0                                1.5                              5.33
243.34 1800                     31.14                        30061                     82                            0                               0                               0                                1.44                             0                                1.42                             6.97
243.92 2040                     33.11                        31940                     82                            0                               0                               -0.8                             1.46                             -3.9                             1.5                              6.56
244.51 2280                     36.42                        33957                     82                            0                               0                               -3.9                             1.54                             0                                1.42                             6.15
245.08 2560                     40.83                        36264                     82                            0                               0                               0                                1.46                             -3.1                             1.56                             6.15
245.66 2840                     46.72                        38820                     152                           0                               0                               -0.8                             1.46                             -3.1                             1.44                             6.56
246.24 2280                     37.47                        41180                     152                           0                               0                               -4.7                             1.6                              0                                1.52                             6.56
246.85 1840                     12.75                        42519                     152                           0                               0                               3.9                              1.6                              -2.3                             1.58                             4.51
247.43 1760                     12.22                        43296                     152                           0                               0                               6.3                              1.58                             -0.8                             1.48                             3.28
248.02 1680                     11.47                        43975                     108                           0                               0                               0                                1.44                             3.1                              1.5                              2.87
248.59 1520                     10.83                        44579                     108                           0                               0                               3.9                              1.46                             -1.6                             1.48                             2.87
249.17 1280                     9.78                         45099                     108                           0                               0                               1.6                              1.48                             -2.3                             1.5                              2.87
249.74 1000                     8.5                          45592                     108                           0                               0                               -1.6                             1.58                             3.1                              1.56                             3.28
250.32 760                      6.75                         45982                     38                            0                               0                               2.3                              1.5                              -3.1                             1.48                             3.28
250.92 720                      6.11                         46403                     38                            0                               0                               -3.9                             1.44                             1.6                              1.5                              4.1
251.52 680                      6.53                         46777                     38                            0                               0                               -3.9                             1.5                              1.6                              1.5                              3.69
252.08 680                      6.33                         47128                     38                            0                               0                               1.6                              1.54                             -3.1                             1.52                             3.69
252.67 680                      7.94                         47510                     28                            0                               0                               -3.1                             1.56                             2.3                              1.54                             4.1
253.26 680                      7                            47917                     28                            0                               0                               -2.3                             1.58                             3.1                              1.54                             4.1
253.83 720                      7.72                         48390                     28                            0                               0                               1.6                              1.58                             0.8                              1.54                             4.51
254.41 1200                     18.64                        49394                     28                            0                               0                               0                                1.52                             0.8                              1.54                             6.56
254.99 1360                     18.69                        50580                     28                            0                               0                               -4.7                             1.44                             1.6                              1.5                              5.74
255.57 1440                     19.72                        51735                     56                            0                               0                               1.6                              1.58                             -3.9                             1.44                             5.33
256.15 1560                     20.33                        52898                     56                            0                               0                               -3.9                             1.52                             1.6                              1.5                              5.33
256.76 1720                     20.58                        54127                     56                            0                               0                               0.8                              1.46                             -3.9                             1.56                             4.92
257.33 1960                     29.64                        55615                     56                            0                               0                               0                                1.38                             0                                1.38                             5.74
257.91 2640                     94.89                        59743                     94                            9                               6                               0                                1.42                             0                                1.46                             11.89
258.49 3760                     157.03                       2292                      94                            9                               5.3                             -5.5                             1.3                              -4.7                             1.5                              15.99
259.08 3560                     143.28                       12361                     94                            9                               5.3                             -11.7                            0.72                             -10.9                            0.62                             19.27
259.66 3240                     123.69                       19784                     94                            9                               7.5                             -6.3                             1.12                             -4.7                             1.22                             14.76
260.24 3640                     142.17                       29024                     568                           12                              7.5                             -7.8                             1.08                             -5.5                             1.1                              17.22
260.82 4040                     152.47                       38607                     568                           12                              9.8                             -7                               1.16                             -5.5                             1.18                             15.99
261.42 4400                     172.33                       49288                     568                           12                              12                              -7                               1.12                             -4.7                             1.16                             15.99
262.06 4800                     181.75                       60781                     568                           11.3                            12                              -7.8                             1.24                             -5.5                             1.2                              15.58
262.69 5120                     201.28                       8264                      774                           11.3                            12                              -8.6                             1                                -5.5                             0.92                             15.58
263.33 4600                     27.97                        16470                     774                           0                               0                               0                                1.12                             0                                1.08                             8.2
263.92 3240                     17.89                        17700                     774                           0                               0                               0                                1.14                             0                                1.16                             2.46
264.51 2920                     16.31                        18687                     774                           0                               0                               -10.2                            1.5                              -6.3                             1.46                             2.46
265.08 2640                     15.31                        19469                     336                           0                               0                               -8.6                             1.5                              -2.3                             1.56                             2.46
265.68 2400                     12.69                        20171                     336                           0                               0                               -0.8                             1.6                              -6.3                             1.56                             2.46
266.27 2200                     13                           20855                     336                           0                               0                               0                                2.92                             0                                2.92                             2.46
266.84 2040                     11.36                        21495                     336                           0                               0                               0                                3.38                             0                                3.82                             2.46
267.42 1960                     10.11                        22104                     50                            0                               0                               0                                3.48                             0                                4.16                             2.46
268.01 1960                     23.61                        22771                     50                            0                               0                               3.9                              1.82                             18                               2.18                             2.46
268.58 1960                     29.33                        24135                     50                            8.3                             9                               -3.1                             1.16                             -5.5                             1.04                             5.74
269.19 1960                     29.03                        25731                     50                            8.3                             9                               -3.1                             1.54                             -7.8                             1.4                              5.33
269.78 1960                     29.03                        27292                     88                            8.3                             9                               -8.6                             1.5                              -3.1                             1.48                             5.33
270.34 2000                     27.31                        28817                     88                            8.3                             9                               -3.9                             1.46                             -7                               1.56                             5.33
270.92 2000                     15.17                        29970                     88                            0                               0                               0.8                              1.66                             -4.7                             1.56                             3.69
271.5  1960                     14.17                        30767                     88                            0                               0                               -3.1                             1.48                             1.6                              1.56                             2.87
272.08 2000                     26.17                        32023                     86                            5.3                             6                               -3.1                             1.34                             -6.3                             1.4                              4.92
272.68 1960                     24.86                        33400                     86                            5.3                             6                               -7                               1.56                             -1.6                             1.44                             4.92
273.27 2000                     24.25                        34728                     86                            5.3                             6                               -7                               1.42                             -1.6                             1.54                             4.51
273.84 2000                     24.33                        36080                     86                            5.3                             6                               -1.6                             1.48                             -5.5                             1.5                              4.51
274.42 2000                     23.06                        37393                     98                            5.3                             6                               -5.5                             1.56                             -0.8                             1.46                             4.51
275    2000                     22.36                        38661                     98                            5.3                             6                               -6.3                             1.4                              0                                1.54                             4.51
275.58 2000                     13.44                        39664                     98                            0                               0                               1.6                              1.58                             -3.9                             1.46                             3.28
276.16 1960                     17.92                        40438                     98                            0                               0                               -2.3                             1.56                             2.3                              1.5                              2.87
276.77 1960                     24.08                        41648                     98                            1.5                             2.3                             -7                               1.38                             -1.6                             1.46                             4.51
277.35 1960                     12.36                        42790                     78                            0                               0                               -0.8                             1.58                             -6.3                             1.46                             4.1
277.93 1920                     12.39                        43528                     78                            0                               0                               -3.9                             1.54                             0.8                              1.56                             2.87
278.52 1880                     17.56                        44385                     78                            0                               0                               1.6                              1.46                             -3.1                             1.54                             3.28
279.1  1880                     12.89                        45432                     78                            0                               0                               0                                1.54                             -6.3                             1.4                              3.69
279.68 1840                     12.22                        46179                     68                            0                               0                               -3.1                             1.5                              0                                1.54                             2.87
280.27 1840                     14.42                        46942                     68                            0                               0                               6.3                              1.58                             -1.6                             1.56                             3.28
280.86 1840                     16.44                        47841                     68                            0                               0                               7.8                              1.56                             -0.8                             1.48                             3.69
281.44 1840                     17.61                        48804                     68                            0                               0                               1.6                              1.42                             3.9                              1.48                             3.69
282.03 1840                     23.08                        50109                     62                            0                               0                               2.3                              1.42                             -3.9                             1.5                              4.92
282.6  1840                     24.94                        51480                     62                            0                               0                               3.1                              1.56                             -3.9                             1.46                             5.33
283.18 1880                     29.61                        53094                     62                            0                               0                               -3.1                             1.44                             0.8                              1.54                             6.15
283.76 1880                     29.31                        54807                     62                            0                               0                               0.8                              1.44                             -3.9                             1.54                             6.15
284.34 1960                     34.14                        56625                     112                           0                               0                               -3.9                             1.56                             0                                1.46                             6.56
284.94 2000                     45.28                        59008                     112                           0                               0                               -4.7                             1.32                             -0.8                             1.48                             8.2
285.53 2040                     13.17                        60555                     112                           0                               0                               6.3                              1.68                             0.8                              1.62                             4.51
286.1  2000                     12.36                        61352                     112                           0                               0                               3.1                              1.56                             7.8                              1.56                             2.87
286.68 1960                     21.28                        62124                     112                           0                               0                               2.3                              1.38                             6.3                              1.44                             2.87
287.26 2000                     30.39                        63628                     112                           0                               0                               1.6                              1.48                             -3.9                             1.44                             4.92
287.84 2040                     37                           12                        112                           0                               0                               -3.9                             1.52                             0                                1.44                             6.15
288.42 2080                     35.22                        2096                      112                           0                               0                               -0.8                             1.44                             -3.1                             1.56                             6.97
289.03 2120                     29.03                        3905                      124                           0                               0                               0                                1.56                             -3.1                             1.46                             5.74
289.6  2160                     24.97                        5508                      124                           0                               0                               -3.1                             1.58                             1.6                              1.48                             4.92
290.18 2160                     25.39                        6975                      124                           0                               0                               0.8                              1.44                             -3.1                             1.54                             4.51
290.76 2200                     23.64                        8353                      124                           0                               0                               2.3                              1.56                             -2.3                             1.46                             4.51
291.34 2200                     14.11                        9446                      106                           0                               0                               -0.8                             1.56                             3.9                              1.58                             3.28
291.92 2160                     11.86                        10208                     106                           0                               0                               5.5                              1.52                             0                                1.5                              2.46
292.5  2120                     12.33                        10905                     106                           0                               0                               5.5                              1.54                             0                                1.5                              2.46
293.11 2080                     12.03                        11585                     106                           0                               0                               1.6                              1.48                             6.3                              1.56                             2.46
293.69 1880                     9.89                         12210                     52                            0                               0                               0                                1.84                             0                                1.94                             2.46
294.28 1720                     8.5                          12724                     52                            0                               0                               0                                3.1                              0                                3.06                             2.46
294.85 1560                     7.83                         13162                     52                            0                               0                               0                                3.34                             0                                3.52                             2.46
295.43 880                      11.94                        13568                     52                            0                               0                               0                                2.28                             0                                2.46                             2.87
296.01 1120                     15.39                        14348                     38                            0                               0                               0                                1.56                             0                                1.64                             4.1
296.59 1680                     54.94                        16779                     38                            4.5                             4.5                             0                                1.42                             0                                1.44                             12.3
297.19 1280                     40.28                        19195                     38                            4.5                             4.5                             1.6                              1.54                             -1.6                             1.5                              12.71
297.78 1360                     43.5                         21694                     38                            3.8                             3.8                             -2.3                             1.56                             0.8                              1.46                             12.3
298.35 1400                     42.44                        24258                     38                            3.8                             3.8                             -2.3                             1.46                             0.8                              1.58                             12.3
298.93 1480                     36.89                        26552                     180                           3.8                             3.8                             0.8                              1.56                             -3.1                             1.48                             10.25
299.51 1560                     34.89                        28629                     180                           3.8                             3.8                             0                                1.38                             0                                1.46                             9.02
300.09 1520                     11.28                        29561                     180                           0                               0                               1.6                              1.6                              2.3                              1.62                             3.69
300.68 1520                     10.75                        30219                     180                           0                               0                               7.8                              1.58                             3.9                              1.6                              3.28
301.28 1520                     17.67                        31058                     104                           0                               0                               0.8                              1.42                             7.8                              1.46                             4.1
301.84 1520                     25.19                        32194                     104                           0.8                             0.8                             1.6                              1.36                             -2.3                             1.4                              4.92
302.42 2080                     26.47                        33668                     104                           0                               0                               1.6                              1.56                             -3.9                             1.42                             4.92
303    2120                     25.78                        35220                     104                           0                               0                               -3.1                             1.5                              0.8                              1.48                             4.92
303.58 3160                     39.28                        37189                     94                            0                               0                               0                                1.42                             -2.3                             1.54                             4.92
304.18 3240                     65.19                        40380                     94                            0                               0                               0                                1.4                              0                                1.34                             7.38
304.77 3400                     83.39                        44940                     94                            3                               0                               -4.7                             1.5                              -0.8                             1.44                             9.43
305.34 3600                     90.72                        49953                     94                            3                               0                               -1.6                             1.3                              -2.3                             1.38                             9.84
305.93 3760                     33.5                         53566                     290                           0                               0                               -4.7                             1.6                              1.6                              1.5                              5.33
306.52 3720                     21.28                        55021                     290                           0                               0                               -1.6                             1.5                              4.7                              1.58                             2.87
307.09 3600                     19.83                        56186                     290                           0                               0                               3.9                              1.58                             2.3                              1.58                             2.46
307.69 3560                     29.86                        57754                     290                           0                               0                               -2.3                             1.5                              3.9                              1.4                              3.69
308.28 3520                     32.78                        59584                     118                           0                               0                               -4.7                             1.42                             2.3                              1.54                             4.1
308.85 3480                     34.61                        61461                     118                           0                               0                               -0.8                             1.44                             -3.1                             1.46                             4.1
309.43 3480                     35.17                        63444                     118                           0                               0                               -4.7                             1.56                             0.8                              1.46                             4.1
310.01 3440                     23.81                        65230                     118                           0                               0                               -0.8                             1.48                             -3.9                             1.56                             4.1
310.59 3360                     18.78                        866                       130                           0                               0                               1.6                              1.58                             -2.3                             1.5                              2.46
311.18 3240                     17.86                        1898                      130                           0                               0                               -1.6                             1.54                             3.1                              1.46                             2.46
311.79 3120                     17.56                        2907                      130                           0                               0                               3.1                              1.44                             -1.6                             1.56                             2.46
312.36 3000                     17.17                        3868                      130                           0                               0                               0                                2.4                              0                                2.02                             2.46
312.94 2840                     16.42                        4787                      72                            0                               0                               0                                3.56                             0                                3.08                             2.46
313.53 2640                     15.17                        5622                      72                            0                               0                               0                                4.1                              0                                3.24                             2.46
314.1  2360                     13.58                        6040                      72                            0                               0                               0                                4.1                              0                                4                                0
314.69 2080                     12.56                        6040                      72                            0                               0                               0                                4.28                             0                                4.06                             0
315.28 1800                     9.44                         6040                      26                            0                               0                               0                                4.18                             0                                4.16                             0
315.85 1520                     11.17                        6470                      26                            0                               0                               0                                2.36                             0                                2.7                              2.87
316.43 1360                     11.22                        7041                      26                            0                               0                               0                                1.84                             0                                1.98                             2.87
317.01 1240                     10.03                        7591                      26                            0                               0                               0                                1.66                             0                                1.7                              3.28
317.59 1160                     18.44                        8238                      38                            0                               0                               3.9                              1.6                              3.9                              1.58                             3.69
318.17 1360                     22.06                        9551                      38                            0                               0                               0                                1.42                             0                                1.4                              6.97
318.76 1760                     34.06                        11410                     38                            0                               0                               0                                1.42                             0                                1.4                              7.38
319.36 1960                     48.03                        13804                     38                            0                               0                               0                                1.42                             0                                1.4                              10.25
319.94 2200                     54.31                        16838                     38                            0                               0                               0                                1.4                              0                                1.44                             9.84
320.53 2520                     95.67                        21360                     156                           3                               6                               0                                1.36                             0                                1.38                             13.12
321.1  2760                     105.22                       27155                     156                           9                               6                               -2.3                             1.1                              -3.1                             1.12                             14.35
321.68 3040                     122.14                       34147                     156                           9                               6                               -7.8                             1.24                             -7                               1.24                             15.17
322.26 3480                     146.92                       42161                     156                           12                              9                               -5.5                             0.9                              -3.9                             1.02                             15.99
322.86 3840                     120.11                       51192                     476                           12                              9                               0                                0.38                             0                                0.58                             16.81
323.44 3840                     26.78                        53962                     476                           0                               0                               0                                0.9                              0                                1.06                             4.1
324.03 3760                     20.94                        55289                     476                           0                               0                               -3.9                             1.2                              -4.7                             1.34                             2.87
324.6  3640                     21.03                        56422                     476                           0                               0                               -8.6                             1.5                              -1.6                             1.46                             2.46
325.18 3520                     20                           57565                     232                           0                               0                               -3.9                             1.44                             -4.7                             1.52                             2.46
325.76 3400                     24.39                        58699                     232                           0                               0                               -3.9                             1.4                              5.5                              1.58                             2.46
326.34 3400                     27.14                        60261                     232                           0                               0                               -8.6                             1.4                              -0.8                             1.46                             3.28
326.94 3360                     25.61                        61689                     232                           0                               0                               -3.9                             1.44                             -6.3                             1.48                             3.28
327.53 3280                     18.53                        62821                     96                            0                               0                               -7.8                             1.56                             -0.8                             1.48                             2.46
328.1  3160                     18                           63794                     96                            0                               0                               -4.7                             1.5                              0.8                              1.6                              2.46
328.68 3120                     17.67                        64967                     96                            0                               0                               -4.7                             1.5                              -7.8                             1.42                             2.87
329.26 2920                     17                           359                       96                            0                               0                               -9.4                             1.54                             -2.3                             1.48                             2.46
329.83 2480                     14.56                        1088                      72                            0                               0                               0                                2.08                             0                                2.1                              2.46
330.43 1640                     8.42                         1088                      72                            0                               0                               0                                3.66                             0                                3.46                             0
331.03 1240                     6.03                         1110                      72                            0                               7.5                             0                                3.26                             0                                3.34                             0
331.59 1400                     13.08                        1913                      72                            0                               0                               0                                1.68                             0                                1.76                             4.1
332.17 1440                     42.58                        3101                      30                            3                               0                               0                                1.26                             0                                1.32                             6.15
332.75 1560                     56.86                        5498                      30                            3                               0                               0                                1.22                             0                                1.28                             10.66
333.33 1480                     48.28                        8312                      30                            3                               3                               0                                1.26                             0                                1.3                              13.12
333.94 1600                     50.5                         11287                     30                            3                               3                               -5.5                             1.54                             -7.8                             1.46                             12.3
334.77 1720                     57.94                        15570                     194                           3                               3                               0                                1.36                             0                                1.32                             12.3
335.36 1640                     7.14                         17061                     194                           0                               0                               0                                1.26                             0                                1.3                              4.51
335.93 1320                     10.75                        17602                     194                           0                               0                               0                                1.48                             0                                1.52                             3.28
336.51 1280                     10.11                        18163                     194                           0                               0                               -2.3                             1.52                             2.3                              1.52                             3.28
337.1  1280                     5.72                         18688                     88                            0                               0                               -2.3                             1.46                             2.3                              1.52                             2.87
337.67 1120                     6.08                         19050                     88                            0                               0                               2.3                              1.56                             -1.6                             1.6                              2.46
338.25 1240                     9.89                         19567                     88                            0                               0                               -4.7                             1.36                             3.1                              1.48                             3.28
338.86 1200                     9.53                         20084                     88                            0                               0                               -6.3                             1.48                             0.8                              1.46                             3.28
339.43 1160                     8.56                         20558                     34                            0                               0                               0.8                              1.56                             -2.3                             1.52                             2.87
340.01 1120                     7.86                         20998                     34                            0                               0                               -2.3                             1.56                             3.1                              1.58                             2.87
340.6  1080                     6.92                         21438                     34                            0                               0                               4.7                              1.62                             0.8                              1.58                             2.87
341.17 1080                     7.39                         21878                     34                            0                               0                               5.5                              1.58                             0.8                              1.58                             2.87
341.75 1040                     6.78                         22298                     32                            0                               0                               0                                1.54                             6.3                              1.56                             2.87
342.36 1040                     6.31                         22674                     32                            0                               0                               4.7                              1.56                             0.8                              1.52                             2.87
342.93 1000                     6.83                         23052                     32                            0                               0                               4.7                              1.56                             0.8                              1.54                             2.87
343.51 1160                     13.25                        23703                     32                            0                               0                               0                                1.5                              6.3                              1.56                             4.51
344.1  1160                     14                           24506                     38                            0                               0                               3.9                              1.58                             -1.6                             1.54                             4.51
344.67 1000                     7                            25175                     38                            0                               0                               -1.6                             1.54                             3.1                              1.56                             4.1
345.25 1000                     7.39                         25647                     38                            0                               0                               -3.1                             1.48                             2.3                              1.5                              3.28
345.86 1000                     7.64                         26087                     38                            0                               0                               2.3                              1.54                             -2.3                             1.52                             3.28
346.43 1000                     6.61                         26483                     36                            0                               0                               -2.3                             1.5                              3.1                              1.54                             2.87
347.02 1000                     6.39                         26877                     36                            0                               0                               -1.6                             1.52                             3.1                              1.52                             2.87
347.61 960                      6.58                         27231                     36                            0                               0                               3.1                              1.54                             -2.3                             1.5                              2.87
348.18 1080                     6.94                         27600                     36                            0                               0                               -1.6                             1.56                             3.1                              1.58                             2.87
348.76 1120                     7.86                         28026                     28                            0                               0                               -0.8                             1.56                             3.9                              1.54                             2.87
349.34 1040                     7.44                         28456                     28                            0                               0                               1.6                              1.48                             -3.1                             1.44                             2.87
349.92 1120                     12.06                        28911                     28                            0                               0                               -1.6                             1.6                              2.3                              1.56                             2.87
350.52 1520                     30.03                        30296                     28                            0                               0                               0                                1.46                             0                                1.5                              7.38
351.11 1520                     40.31                        32408                     28                            0                               0                               0                                1.42                             0                                1.44                             9.02
351.69 1520                     56.44                        35268                     82                            6                               0.8                             0                                1.4                              0                                1.4                              12.3
352.27 1680                     56.67                        38497                     82                            6                               4.5                             -0.8                             1.44                             -4.7                             1.5                              13.12
352.86 1760                     49.17                        41681                     82                            6                               4.5                             0                                1.44                             0                                1.36                             12.3
353.43 1800                     7.56                         43336                     82                            0                               0                               0                                1.46                             0                                1.4                              4.92
354.01 1320                     10.42                        43883                     192                           0                               0                               2.3                              1.58                             0.8                              1.56                             2.87
354.59 1320                     9.42                         44393                     192                           0                               0                               7.8                              1.6                              0                                1.58                             2.87
355.19 1280                     7.61                         44891                     192                           0                               0                               2.3                              1.5                              6.3                              1.56                             2.87
355.77 1120                     5.69                         45274                     192                           0                               0                               2.3                              1.56                             -1.6                             1.56                             2.46
356.36 1120                     8.58                         45703                     34                            0                               0                               -0.8                             1.54                             5.5                              1.56                             2.87
356.93 1040                     7.92                         46153                     34                            0                               0                               -1.6                             1.52                             4.7                              1.52                             2.87
357.51 1000                     7.89                         46604                     34                            0                               0                               3.9                              1.54                             -0.8                             1.5                              3.28
358.09 960                      7.92                         47022                     34                            0                               0                               -0.8                             1.52                             3.9                              1.52                             3.28
358.69 1360                     34.22                        47953                     32                            3                               1.5                             0.8                              1.48                             0                                1.46                             4.92
359.27 1480                     54.53                        49979                     32                            4.5                             4.5                             0                                1.48                             0                                1.48                             11.48
359.86 1320                     43.08                        52495                     32                            3.8                             4.5                             0                                1.52                             0                                1.5                              12.71
360.42 1440                     45.22                        55145                     32                            6.8                             3.8                             -3.1                             1.46                             0.8                              1.5                              12.71
361    1560                     52.5                         57970                     168                           6.8                             3.8                             0.8                              1.52                             -3.9                             1.46                             12.71
361.58 1640                     54.28                        61072                     168                           6.8                             3.8                             -3.1                             1.54                             -0.8                             1.48                             12.71
362.16 1760                     61.61                        64332                     168                           6.8                             3.8                             0                                1.46                             -3.9                             1.5                              12.71
362.76 1800                     8.36                         1371                      168                           6                               3.8                             0                                1.26                             0                                1.22                             10.66
363.35 1680                     11.67                        2061                      190                           0                               0                               1.6                              1.58                             0                                1.52                             2.87
363.92 1240                     10.25                        2586                      190                           0                               0                               5.5                              1.6                              0                                1.58                             2.87
364.5  1200                     9.19                         3111                      190                           0                               0                               7.8                              1.58                             2.3                              1.58                             3.28
365.08 1160                     5.11                         3564                      190                           0                               0                               -2.3                             1.52                             2.3                              1.56                             2.87
365.66 1120                     8.33                         4003                      36                            0                               0                               3.1                              1.56                             -0.8                             1.5                              2.87
366.26 1040                     7.94                         4454                      36                            0                               0                               -2.3                             1.5                              3.1                              1.5                              3.28
366.85 960                      8.08                         4883                      36                            0                               0                               -2.3                             1.5                              2.3                              1.48                             3.28
367.42 1080                     8.19                         5323                      36                            0                               0                               3.9                              1.58                             -1.6                             1.56                             3.28
368    1000                     7.72                         5785                      32                            0                               0                               0                                1.54                             4.7                              1.56                             3.28
368.6  920                      6.89                         6205                      32                            0                               0                               -1.6                             1.52                             3.9                              1.48                             3.28
369.18 800                      6.28                         6557                      32                            0                               0                               3.1                              1.52                             -2.3                             1.5                              3.28
369.76 680                      8.11                         6921                      32                            0                               0                               -1.6                             1.52                             3.1                              1.52                             3.69
370.35 680                      5.5                          7274                      26                            0                               0                               -2.3                             1.52                             3.1                              1.5                              3.69
370.94 640                      7.25                         7619                      26                            0                               0                               2.3                              1.5                              -2.3                             1.5                              3.69
371.52 680                      6.25                         8006                      26                            0                               0                               -3.1                             1.48                             1.6                              1.5                              4.1
372.11 640                      8.78                         8433                      26                            3                               3                               0                                1.46                             0                                1.46                             5.74
372.68 720                      8.39                         8914                      26                            3                               3                               0.8                              1.48                             -4.7                             1.46                             4.51
373.26 680                      7.28                         9345                      30                            0                               0                               -3.9                             1.5                              0                                1.48                             4.1
373.85 640                      6.83                         9737                      30                            0                               0                               0.8                              1.5                              -5.5                             1.48                             4.1
374.69 600                      6.58                         10262                     30                            0                               0                               -0.8                             1.46                             -6.3                             1.46                             4.1
375.27 600                      6.25                         10633                     28                            0                               0                               -7                               1.42                             -2.3                             1.48                             4.1
375.86 600                      5.78                         10955                     28                            0                               0                               -8.6                             1.46                             -3.1                             1.46                             4.1
376.43 600                      5.86                         11274                     28                            0                               0                               -3.9                             1.48                             -8.6                             1.46                             3.69
377.01 560                      5.81                         11573                     28                            0                               0                               -9.4                             1.48                             -4.7                             1.5                              3.69
377.6  560                      5.83                         11872                     22                            0                               0                               -9.4                             1.52                             -3.9                             1.5                              3.69
378.17 600                      5.53                         12184                     22                            0                               0                               -3.9                             1.52                             -9.4                             1.5                              3.69
378.75 560                      5.56                         12483                     22                            0                               0                               -8.6                             1.54                             -4.7                             1.54                             3.69
379.34 560                      5.64                         12782                     22                            0                               0                               -8.6                             1.54                             -3.9                             1.52                             3.69
379.93 560                      5.56                         13068                     22                            0                               0                               -3.9                             1.54                             -9.4                             1.54                             3.69
380.51 560                      5.61                         13367                     20                            0                               0                               -8.6                             1.54                             -3.9                             1.54                             3.69
381.1  560                      5.58                         13666                     20                            0                               0                               -3.9                             1.54                             -8.6                             1.54                             3.69
381.67 560                      5.5                          13952                     20                            0                               0                               -3.9                             1.52                             -7.8                             1.56                             3.69
382.25 560                      5.69                         14251                     20                            0                               0                               -8.6                             1.54                             -3.1                             1.54                             3.69
382.84 560                      5.5                          14563                     20                            0                               0                               -3.1                             1.56                             -7.8                             1.54                             3.69
383.41 560                      5.56                         14862                     20                            0                               0                               -3.1                             1.54                             -7.8                             1.54                             3.69
384.01 560                      5.5                          15148                     20                            0                               0                               -7.8                             1.56                             -2.3                             1.54                             3.69
384.6  560                      5.5                          15447                     20                            0                               0                               -2.3                             1.54                             -7                               1.54                             3.69
385.17 560                      5.44                         15746                     20                            0                               0                               -2.3                             1.54                             -7                               1.54                             3.69
385.75 560                      5.58                         16032                     20                            0                               0                               -7                               1.56                             -2.3                             1.54                             3.69
386.34 560                      5.53                         16344                     20                            0                               0                               -2.3                             1.54                             -7                               1.54                             3.69
386.91 560                      5.58                         16630                     20                            0                               0                               -7                               1.52                             -1.6                             1.54                             3.69
387.51 560                      5.44                         16929                     20                            0                               0                               -7                               1.54                             -1.6                             1.52                             3.69
