Old 4th October 2016, 10:23 PM
If it responds to down but does absolutely nothing for up then its probably a switch which has failed. Each window in the system apart from the driver's relies on both switches working so it could be either front or rear which has failed.
Since you have to take the switch panels out before you can take the door card off its worth swapping them about to see if it helps
