Originally Posted by jt racing
Ok a update. Got home eventually, over 2/3rds of fuel in it but it just died till I gave it another gallon?!?!would it not be seated right?
Had the same problem with my car when I bought it due a change of pump. Tried refitting it a few times myself (even bought an endoscope/borescope so that I could see what was going on down there) but I got sick of crouching in the boot whiffing petrol fumes so I decided to let someone else do it. 3 different garages tried and failed, so I continued to drive the car for 3 years, always filling up whenever it got down to half a tank. Eventually I replaced the entire tank. I suspect in my case something may have been damaged/cracked in the tank, preventing the pump assembly from achieving a perfect seal. Hopefully you'll get yours seated correctly on the next attempt
