Thread: Aaargh - PRNDS!
Old 15th November 2016, 10:08 AM
It also clarifies that if ONLY one Support is removed the other will suffice to hold the transmission in place, otherwise you need a lift under it (VAG1383A)
That is optimistic in the extreme! You can't get the mount out with weight on it, so you have to jack up the back of the transmission to remove it. I found that out when I forgot to re-attach the shifter cable after putting the engine back in the first time
The bolt behind the downpipe is going to require a special took I think. Its actually not that painful to move that downpipe on mine as I have the SAI removed so I can get to the top manifold bolt, but on a stock car you'd really want to do it without moving the downpipe so you need a super-short T27 I think.
As the Titanic is still on the lift (don't ask) I can't check for a week or two so I'm just going to have to live with it on mine for a bit
