Originally Posted by daedalusminos
The gauge used to sit and stay spot on 90C, ...
Jonathan
All VAG instrument panels tell fibs
They are all programmed to show 90degrees exactly within a range of about +- 10 degrees. That is they show 90 at all temperatures between 80 and 100
I've seen this 'fib' myself running VCDS monitoring the Engine ECU [which is where the temperature sensor sends its info]. So you can't trust what the guage says when you're having problems
Julian
