Old 3rd December 2016, 02:15 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
MGF wiper linkages were pretty easy to overhaul as their design allowed a m8 nut to be braised on to the end of the linkage rods and a suitable rose joint screwed in to place. The modern folded steel linkage rod is a bit more difficult to work with. You cant simply braise the rose joint on as the bushing inside gets melted by the heat and you end up with new 'worn' links straight away
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
