  #229
Old 8th December 2016, 10:22 AM
2. Pulling out of a side road and accelerating the car only speeds up "gently" not "urgently" as I expect. No ABS/ESP warnings or symptoms. Only seen within the first minute or so of driving the car and not always by any means.
Interestingly, since having 'mended' my F125, mine is now doing this most of the time. The first 50% of the throttle does very little, but prod it a bit further and it takes off like a rocket. It happens mostly in 1st which is very annoying, but also randomly in other gears. If I'm in town pootling around at 30 and slow down for something it'll take a hefty prod to make it move, at which point it changes down to 2nd and goes a bit nuts. Its much better behaved in tiptronic, to the point I had to tow the FE home entirely in tip otherwise it would barely move. No codes either.
Time for a new switch methinks...
