Originally Posted by green A8
Ian As you're the expert on this forum I wonder if I could pester you to answer another question. I plan to fit a solar sunroof on our other 1996 D2. This car also has the 'full' loom fitted. Would the required solar sunroof harness be present within the loom (fuse, relay block ect)?
From memory the wiring will be there. It is a two wires bundled inside a black plastic sheath terminated by a yellow round 2 pin plug.
It should be underneath the passenger side door sill trim.
It will need running up the passenger A pillar towards the roof.
Then, you need to install the solar roof, 2 contacts and two cables which will come down the A pillar and plug into it.
There is a relay holder in the footwell which has a bar across it connecting the battery to the fans permanently. Just replace this with a relay and all your work is done. Its so easy working on the early cars. You will have a fully wired towbar connection in there too
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
