View Single Post
Old 22nd December 2016, 08:34 AM
It's not as scary as you think really, any good VAG-skilled independent should be able to do it. The drain/filter/fill that is.
My local did both my old and new (current) ones but do also have the benefit of some quite good people including some who used to work at Fontain (a big independent in Iver). They also said up front that they would order from Audi and use genuine/correct parts.
My first one improved a lot, but was probably too late anyway. What came out was pretty mucky and the car didn't last much longer anyway, for various reasons.
The second one was done around 70,000 miles and what came out was clean. It has been fine for the well over 3 years since then apart from glitches that have been (finally!) tracked down to the F125 switch, now replaced with great results.
I'd seriously look at replacing the F125 switch at the same time, though that will add a fair bit to the labour (and about £150 parts).
