Old 24th December 2016, 04:58 PM
I've got a full kit in the garage for retrofitting MFSW.
It's a combination of A4 and A6 bits but it works fine on the RNS-c/d. I tested it OK the bench. As it doesn't use Canbus, it's relatively easy to retrofit if you got the correct steering wheel.
This will work fine in a facelift D2, but not on the OP 1996 car.
RNS-C uses canbus for talking directly to the multi function steering wheel controller, TV, phone and instrument cluster.
RNS-D uses a different canbus protocol, but passes it via the TMC gateway behind the cluster that converts it from blaupunkt canbus into Audi canbus, so the TMC gateway sits on the same infotainment bus as the phone, TV and cluster. This why when you retrofit an RNS-E, that talks proper audi canbus, you have to cut the TMC out of the loop.
In 1996, Prefacelift, the protocol is 3LB that is used for talking from the head unit to the instrument cluster, and its used only for displaying information, not for receiving any sort of control signals.
To my knowledge, there is no way to fit a MFSW to a 1996 car and have it do the audio controls.
Tiptronic, yes. Heated function, yes. Audio or phone, no.
