Old 25th December 2016, 02:33 PM
Spanker's Avatar
Spanker Spanker is offline
Looks like its the connection piece of the 26-way multi plug on the left of this pic, but with its outer shell removed. Did you have anything in that spot?
If that is it, it should have a shell like this on it:
Yes, The black connector with the turquoise lever lock is present. As is everything else in that diagram with the exception of the:
"Brown Ground Connector(not used in Sym II)"
"8 Pin connector II"
I hope that having nothing in the Brown Ground Connector and 8 Pin connector is normal. Although I notice that for the AM/FM antenna inputs, I have leads into both - suggesting Sym 1, but the Brown Ground Connector is missing, suggesting Sym II. And David's8 suggested in another thread about missing console illumination may be a symptom of poor ground.
So I am little confused, not being an auto-electrician.
But that connector lead (as in my photo) does seem to go behind the glove box. To where I am not sure. When I am next in the car I will see if I can trace it back without the need to dismantle much. There is a vestigial hands-free mic near the front courtesy lights (left by a previous owner) so that may be the culprit. But there's a lot of coloured wires in it for just a mic.
I shall investigate further.
Dean
