Originally Posted by IT
Its too shallow to be part of the big multi block. The strips inside that are always blue in my experience.
If I was a betting man, I'd say its more likely from a parrot or some similar aftermarket rubbish that has been removed in a hurry at some point and the wires just tucked behind.
I imagine lifting the passenger side floor mats, wooden cover and left hand transmission tunnel cover may reveal some more aftermarketisms as there is little room around the glovebox itself for modules, but its a common wiring route for hacks.....
I thought I would have a look yesterday evening and attempt to remove the wire as per Ian's suggestion (if it wasn't connected to something important).
I tugged from behind the glove box to get the wire dangling from underneath the glove box. I then removed the floor mat and then the carpet.
Oh dear!
Dampness
Not soaking, but a thin layer of moisture on the black plastic under the mat and the wooden board looked as though it was damp in a "wet cardboard" kind of way.
It was dark and cold so I just left it and came inside and today it's not much warmer so I shall look at it another day.
I found a thread on this forum that linked to this
page so I guess I will be blowing air through tubes in the near future if nothing else gives rise to the cause.
Funny (not!) how one thing leads to another isn't it?
I've got a problem with:
a) Some of my glowing cabin lights (nav controls, vents, little red ambience lights under mirror, dash swtiches etc.) not working
b) My rear ceiling central interior light (not rear reading lights) not working when the doors are opened or the switch is "on" but working when the front interior light switch is switched "on".
c) ALL parking sensors clicking audibly (when my ear is very close to them) but the error beep and flashing parking sensor switch going off when reverse is selected.
d) The rear window demister taking AGES (10-15 minutes) to clear the screen, perhaps due to too much moisture inside the car.
I wonder how many of the above are related to dampness in the electrics/relays or whether it's just faulty components and replacement parts will need to be sourced from our sponsors? A good dry-out will be first. If anyone recognises the above as common faults with easy solutions then your input would be appreciated.
Dean
Dean
2002 A8 D2 S8 FE -
"Red Dwarf" - Misano Red - Platinum/Silver Interior, PDC, Sat Nav Plus with BOSE and hidden Dension Bluetooth, Multi-changer, Heated Front Seats, Bi-Xenons, FE Wheels, Phone Prep with Nokia 6210, Detachable Towbar, Rear Blinds, S8 plate but no other optional extras
2002 A8 D2 2.8 Quattro Sport -
"Big Red" - Tornado Red (Special Order) - Twist Interior, PDC, Passenger Memory Seats, Symphony II with BOSE, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, 20" FE Wheels, Servotronic Steering
