Old 3rd January 2017, 10:17 PM
Depends what you want for sure. Personally I think 200 notes for a tow bar that needs work is over priced, 50 sounds much more like it and you can buy another bumper with the change even if you have to cut yours.
The tow bar I fitted to the "Traders 8" wasn't removable but that said it was only 2 bolts that held the bar to the bracket under the car, so if you did want to take it off its 10 mins max.
I lost the plastic under tray at speed as I had to cut it to fit the kit, it was about 2 months after fitting and I didn't worry about it. But if you spend a lot of time looking under the back bumper you might want to have a better fix.
