Old 4th January 2017, 05:29 PM
That was the first thing I did when it happened for the first time...and I'm still checking pads every time i get the fault even if I know that there is plenty of meat left on the fronts.
Last time I just did a quick inspection with endoscope camera to check the inner pads due to access in case inner pad does wear quicker due to pistons being seized or whatever, but thats not the case.
I will take the wheels off soon to inspect wiring.
No log of the fault?? You 100% sure?? If there is warning light then why wouldn't be logged in?
I have also put a brand new (new revised type) brake light switch since it started happening. No cure of course.
Also I have disabled TPMS in CAN, Cluster or somewhere else I think before this fault, only because I am waiting for next tyre change, wheels refurb and all new sensors at the same time before summer. Don't know if that is relevant, but worth mentioning just in case.
