Old 14th January 2017, 02:57 PM
I completed this today on the front passenger door of my car using the park linked on ebay earlier (slightly faster train from China I guess?), all working but took a lot longer than expected due to a screw dropping inside the door.
In the instructions from IT it stated
Now, this gets a bit more interesting. You have to hold the handle out a little way and push the torx screw in.
ETKA is slightly different (when I checked after the event)
The TORX screw is a screw in a splined insert that is a friction fit into the plastic holder "part 3", so pushing on it has the effect of moving the plastic holder, unless you push a bit hard when the friction fit fails and you are left with a screw in the bottom of the door.
Door card off, speaker removed, fortunately the screw was steel in an aluminium door so 20 mins of blindly fishing with a magnet and it was found.
Also seems that I do have the handle lights installed, but they must have all failed (I assumed that they were not fitted) - going to order four of those from China I think
Still cant complain, keyless locking fixed for less than a tenner
Name:	A8 D4 Door Handle Removal.png
