Thread: Wet door card
Old 18th January 2017, 03:55 PM
johnny_quattro's Avatar
Default Similar sitch
Originally Posted by Ameiseuk View Post
Is this the only door drain?
I have a similar problem on mine, which I intend to take a look at shortly. Damage to my door 'card' is much worse than your one so I'll try and grab a photo and upload it. I've just had a look on my ElsaWin application and can see that there are two sunroof drains to the front of the car and a further two drains leading to the back. The front drain may be a possible culprit as it ends up tucked inside the door jamb, through a hole situated just above the meaty bottom hinge - picture/diagram attached so you can see what I mean.
Name:	Screenshot from 2017-01-18 16:50:28.png
