  #261
Old 22nd January 2017, 06:41 PM
Spanker's Avatar
Spanker Spanker is offline
From memory any calibration issues with the throttle pot should result in a self-learn cycle if you turn the ignition on but don't touch the throttle or anything else. Can't recall how long, but 30 seconds should be adequate.
With VCDS then as per MJ's advice in measuring blocks will show similar and show if there's a component issue.
Your stored faults look like knackered cats
Thanks. When my VCDS returns I shall be giving that a go.
I tried turning on the ignition and leaving for a minute today but there was no change in the behaviour.
Thanks for the advice on the cats.
Again, I shall rescan soon and then investigate that issue. Sounds expensive to me. I've not repriced cats and I don't particularly want to
Dean
