Originally Posted by a8_sport
In my Audi the kick-down function doesn't work when you use the tiptronic function, can I fix this by adjusting the switch? Have someone done it?
There is a known problem where many of the facelift cars left the factory with the kickdown switch disabled.....
If youre car doesnt kick down when in tiptronic, then kick down is NOT working. It will move down a gear or two, but this is not kick down. Kick down should take you to the lowest possible gear without redlining. You can test this by driving along in tiptronic and moving to the highest gear, eg 4 or 5th. Then, accelerate to the floor, it will change up gears. Then, try and manully change up another gear, if you can do it manually, and it didnt with your foot on the floor, then again, your car didnt kick down, it just responded to demand.
Under the throttle peddle on the facelift is a black button, this is the kickdown switch, and it can be turned clockwise and anti-clockwise. I forget which way is which, but when you turn it 'on' you can hear a slight metalic noise like you are engaging a switch. Anyway, turn it 'the other way' and you should find your kickdown now works properly, and be warned, your car will suddenly feel way faster !!
(when the gearbox is fixed that is... !)
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
