Old 27th January 2017, 06:45 AM
They look precisely like the picture in the first post of this thread - if you don't have the round flash and side light holes in that position, and the silver trim strip running across under the bulb then it's single xenon.
Bi-xenon are pretty distinctive to look at - if in doubt go from normal beam to high beam with lights pointing at a wall and you should see the flap move in the reflection. If you just get more light and the xenon beam doesn't change, then again it's most likely single xenon
