Originally Posted by Jon_viola
Ok. Will do. Do I need to reset the system each time I clear?
Ie turn the ignition on and off?
no you can leave the cable and laptop connected, you are just sending an instruction to the modules to clear any fault codes but some may need you to drive the car before some faults return dependant on what the issue is
