Thread: Hydro-Mounts
Old 2nd February 2017, 01:36 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Originally Posted by Mechcanico Lee View Post
If its a subframe drop to do them better do the subframe mounts whilst your there .......then rear subframe .....then every suspension arm then anti roll bar .....
If you're going that far, might as well drop the unside, clean and reseal. haha
I've removed a set from a breaker and I don't recall it needing to drop the subframe.
As the mounting faces was flatish, all you have to do was remove the bolts, support the engine and lift a little, slide the mounts out and replace.
relatively easy job.
I had the sub frame drops, front or rears.
Trying to align them so they are correct is a bitch!!
[center]
06 3.0TDI Quattro:
Options:
